take out or disconnect the front dif =P then u can go to any dyno
Not keen to go playin around with pulling fuses to stop front diff from activating but. If it is in 2WD mode, wont that give in acurate HP figures?
drop the front drive shaft . its 4 bolts
who gives a f**k about hp figures . do you want it tuned or are you just tryin to have a higher hp than someone else
I give a F**K about HP figure! I want it tuned, boosted AND to know exactley what its got at 4 wheels.
I dont need to know if its got a higher HP than anyone else. I already know I have a bigger cock than most blokes so dont need braggin rights about big HP to compensate...
well you won't know EXACTLY what HP it has at all 4 as every dyno will give different readings, so you will only know roughly how much power it has.
running on 2wd for a tune will be fine.
going to ask the obvious, but you have an aftermarket ecu yeah? if not, then tuning won't do shit (as the stock ecu can't be tuned without some type of piggyback system, etc), and any dyno place should be able to wind the boost up for you and do a power run to see what it gets.
I would be almost cetain it has an after market ECU. There aint much that is stock standard on this car. How would i check the ECU to know its aftermarket?
Also doesnt ANYONE on here know of an AWD dyno that they can reccomend?
Edited by Global_Warmer
pull off the kick panel on the passenger side and look at the ecu. if it has a nissan sticker on it then it is more than likely still stock and isn't a nistune or anything like that. to tell that for sure though you have to open it up. if it is a full aftermarket ecu it will have the brand name on it.
Ok. I have had a look at it and it appears that it is a Mines ECU with its own Id Number stamped onto a gold plaque. So can this ECU be tweeked whilst the car is on a Dyno?
So, seeing as no one has answered the question of where is the best place to get an AWD car dyno'd... Does that mean the NO-ONE on this fine forum has ever had thier GTR dyno'd before? If I find a mob that does it and end up gettin it done, then i will be sure to share it with you :P:):)
I'm pretty sure erina ultratune has an AWD mainline dyno. Its on the coast but still a better option than driving all the way to sydney.
Thanks mate! I checked their website out. Looks like its exactly the place that I am after.
plenty of people have had their GTR on a dyno, but it was no point me telling you any of the places i know of since i'm in QLD. there are a lot of people who would be too lazy to post up. there would also be quite a few who just take them to workshops with rwd dynos, because at the end of the dyno the dyno is simply a tuning tool and you may make 300hp on one dyno then go to a dynoe down the road and only make 280hp. any shop with a 4wd dyno would be able to do a power run for you. it isn't rocket science and doing a simple power run is really no different between a gtr and a 4x4. you just tie it down, put in the data and do the run.
as for tuning the mines ecu, don't know how many places will actually be able to retune it for you. i have a feeling it will be very few, if any. the fact that they are a remapped ecu, means that more than likely you need all the emulator and rom burning stuff, which not many workshops have since it is pretty uncommon to do. they would more than likely need the right software as well, which i doubt many people at all have. it isn't like tuning a PFC or nistune, etc where they are relatively common and software is easily accessible.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
