Dont suppose you have some micrometers and a dial bore gauge? I thought cast pistons with high silicon content usually run tight piston to bore clearances. Perhaps its .0014" or thereabouts...
Sorry mate, but I will give a mate a call today - he has all of this gear.
  • Replies 41
I agree with trent, it will either be too tight a piston to bore, or ring gaps. For your application, i would be running at the higher end of the specs for piston to bore, and maybe add 2 thou to the top ring gap, depending what the spec is. If any of the clearances are less than they should be, i would be asking for the machining costs back.
I'm booking the blick into a workshop today. I'll give them a list of things to report.
Hopefully they come back with some answers.
Thanks Trent and Adriano - This information is very helpful.
Sorry mate, no news yet. Work has me flat out, and I'm trying to find time to lift the block out. It's all disconnected, just need to unbolt the gearbox, and lift it out.
Are they 87mm pistons?
Still looks like a factory hone with that much lip on it, don't normally see that on such a fresh motor.
Go back and look at my thread if you can find it, exact same pictures almost and symtoms. Engine builder totally fudged the piston to bore and gave it almost double on myn.
Pulled the head off my RB30DET not long ago and when I inspected my bores they looked exactly the same as the photos you have posted. Engine buildler suggested that it wasnt scoring and was actually fuel lining the boors or something like that ... will be interesting to see what you get back from your engine builder. Mine wasn't using much oil.
Here is an update from the first inspection drop off. They are pulling it down this week, but a quick look they said:
The Deck finish was really rough - Too rough for a Metal Gasket (I have a cometic 3 layer)
The pistons could be moved A LOT in the bore - Piston to bore clearance could be shitty
No signs of over heating
Mine compression tested really well. But there are scratches in 2 bores that are too big to ignore.
Will have an official report from them by Friday, then to the next machine shop. They will inspect and then rebore & hone. Friend of mine is a qualified mechanic, build 50+ LS1s (remember the oil burning issue) is going to put it together for me. He's very switched on.
Going to get CP pistons, and Spool rods, balance and assemble. Will re-use the bearings if they are ok.
Time to go, talk soon. Hope you're all well.
if the pistons could be moved alot doesnt that mean excessive clearance?
could possibly be excessive temps causing the pistons to grow and come in contact with the bore,
so was the marks definately causing issues?
Yeah would be interested to see the condition of the bearings.
In any event I would be reluctant to re-use them. If your going spool rods then you will most likely need crank work/new bearings anyway.
i just wanted to see if they were hammered, could have been some abnormal combustion going on.
  • 1 month later...
Hi Guys. Post today is limited because we have no power. Got some pics though. Oil pump pics later tonight \ Tomorrow morning.
Sprry about the delay in getting back to you all. Took the engine to a "workshop" and they said "COme back at hteh end of the week. 4 f**king weeks later I went and got it regardless. No report written up, and wanted payment. I gave them half for pulling the motor down.
f**k some people around this town are USELESS.
Anyway.
I have a few things to report, and some pics.
1. The Pistons look normal, but with weird combustion marks. Clean on inlet side, dirty as f**k down exhaust side. Might be normal actually.
2. Pistons have 0.5 stamped on the top. Nothing else. (Pic below)
3. The Big End bearings look like brand new. No marks, no hammering, nothing. Clean as a whistle.
4. The Oil pump - Has circular marks, which look like too much crank thrust to me.
Anyway - Pics.
Edited by The Mafia
Have you had a close look at the hone patern on the cylinders? It seems to be a little all over the place. Its possible the hone is responsible for the rings not bedding in properly, resulting in a lack of lubrication that then caused cylinder gouging. Have a look for more information here:
http://www.hastingsmfg.com/ServiceTips/cylinder_bore_refinishing.htm
I was wondering the same thing - I asked for hastings rings, and if they are, then I'm thinking they may be.
And, the hone marks definitely look shit, I will bring this up during the real inspection.
  • 1 month later...
Not yet - I can't really afford to send it to the inspection crew just yet. Give me a week or two and I will send it down.
Will definitely bump this post when I get some results.
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
