Im a bit confused.
I get some people telling me thier is no real need to fitt after market cams on a turbo engine then other say thier is.
Just wont to know would i be better off just using adj cam gears to change the power band or should i go after market cam?
power aim is no more then 200rwkw as the car is a street car and mainly enters drift and motakana so response and low/midrange touqre is what i am after.
my current modds are
RB20DET
3" split dump pipe and front pipe
3" catback exhasut
45v2 turbo at 14psi (RB25DET series 2)
last dyno run was done at 5 psi (tunner did know how to set the boost controller(a bleed type)) so power was 146rwkw.
the one thing i have noticed is that it is laggy up till 4-4.5k and then it goes. the car does need a tune but would i beinifit from a set of cams in this situation.
https://www.sau.com.au/forums/topic/342085-to-cam-or-not/
same dillema im in, im making about 340hp now but want to bump up to the 400ish mark, getting a fresh head made up for me now, changing to forward facing plenum, swapping my cam gears into the new head and looking at some 276 (or 272 cant remember) and with a tune im hopinh to make that extra 60hp
im making about 18psi by about 4-4.5 with a tdo6 25g so your setup sounds a bit laggy?
https://www.sau.com.au/forums/topic/342085-to-cam-or-not/#findComment-5519065
Should have mention i live in darwin were temps are generly 33deg, but yes the car does need a tune, and it is auto.
Ive included the dyno graph in its current state (ecepet PSI was at 5-6 when this was run and i have pumped it up to 14)
Edited by R TUNE
https://www.sau.com.au/forums/topic/342085-to-cam-or-not/#findComment-5519223
Ive got Hks 272's im mine and there awsome best thing i ever did...
Mods are
KKR480 with 30mm gate
HKS 272 cams with cam gears (some china brand but they still do the job)
stock computer running 10 - 12psi
walbro fuel pump
cams definetly made this setup cracks the gate at 4500rpm, same setup on my brothers car without cams 5200rpm so they make a big difference and keeps making power all the way to 7500 and past it... (but not game enough on standard internals)
https://www.sau.com.au/forums/topic/342085-to-cam-or-not/#findComment-5523379
Yea i know, i think the auto and the warm weather (and tune) are to blame.
as it feels alot more responsive when the tem is around 25 deg compared to 30 deg.
Sounds like you need a FMIC and a retune.
Mods are
walbro fuel pump
Get a tune.
https://www.sau.com.au/forums/topic/342085-to-cam-or-not/#findComment-5523512
bubba yes a tune is in the works i just need to get motivated, ive had my laptop hookup to it with nistune and it is running very well (safe) no detonation what so ever well thats according to the standard ecu anyway.... but it does need a tune just not badly :-p
https://www.sau.com.au/forums/topic/342085-to-cam-or-not/#findComment-5523651
    • Yea the photos aren't the best. When I was pulling the bumper and headlights out there was a bodyshop guy looking on for it, there is a slight bend behind where the passenger headlight is, but we're talking a few MM and there is a little bit of a bend for the reo. That said it's supposedly well within the "Drill a hole in it and pull it out with a slide hammer to be close enough" and be on our way. The other option is to buy a GTR reo for the GTR bumper bits but this is a $2000+ fix for something Mr Hammer can probably do 99% of the job for and everything will/can line up pretty closely-to-good-enough.
    • That's a write off for sure... Part out? 😛 I kid. It looks like the rad support has a minor minor bend in it too where the rep support sits near. Could just be the photos (and me not wearing my glasses right now). Worst case is you can buy a new radiator support, have it swapped over, and leave the car in paint jail for 12 to 18 months while you build the motor to handle twin turbos or a Harrop SC...
    • It seems the definition of "Gregging" something might need to be expanded?
    • This is why I suggested that there is really nothing that can safely be done in the engine bay at this budget level. Just the work to reassure yourself that the engine won't instantly crap itself the moment the boost gets turned up will wear out the piggy bank long before the first turbo gets installed. Spend $10k and still not have any extra performance? My tip is a version of our standard advice from 15 years ago about buying a GTR, which is not to buy one unless you can afford to buy two. The new version is not to modify a GTR unless you have all the funds required to do it all at once, properly, and enough to rebuild it after it blows up.
    • Oh, I forgot to mention this before.  It is accepted that your taking on risk buy turning up the power on a 30 year old stock motor. You can lower the risk with the ECU engine protection, but this is more money on sensors. CAN wideband, oil temp, oil pressure, coolant pressure, fuel pressure, air temp, etc. It adds up quick.  I am a huge fan of running all of the engine protection the ECU offers. You'll have to decide for yourself how you want the engine protection setup and what you think is worth monitoring.
