so my housemates just bought this laurel.. its ghetto as f**k, has history but has been around the block and raped and fingered wayyyy to much.
hes doing a ground up build so kinda suitable but still needs sooo much work.
so we need:
front guards
bonnet
front + rear bars
grill
corner lamps
chrome trims
COMPLETE INTERIOR
reo's
probably alot more. doesnt all have to be from the same person, or neccesarily matching.. but its a start
were in qld, cash or bank transfer, will pay freight.
Cheers.
https://www.sau.com.au/forums/topic/342098-attn-laurel-owners/
trim above dash height is near impossible to find , from there down is cefiro apart from door trims and b pillar , might aswell go for after market guards rio looks similar to cefiro at the front but don't hold me to it . your new best friend is: jesse streeter , look him up on ns.com :P
has vented guards but there f**ked. having 2 cefs in our house makes it easy. Its a long term project so gonna try and get paint/panel done first
streeter! ha! no f**king way.. went through another contact of mine to get cst's in $500 cheaper due to a more realistic 'brokers fee'
yeah? sharing is caring :P , no one will post roof lining which is the only thing i need now :laugh: . fiberglass is pretty easy to repair btw but very messy (read: itchy) to sand , what is he planning on doing with the car? (i.e pig spec , show car etc) if he wants to go for a show car look it might pay to try your local nissan dealer for new stuff (long shot) because most parts floating about these days are pretty average . p.s pics!
Just wants a clean streeter. But this thing is a hack. has been drifted for years with no repect.
Front end is tubbed and shit.
Lol ill share. what sorta stuff do u need.
c33 roof lining :) , nah i'm not sure yet , lots of cefiro stuff but that's tba . there was a complete c33 with the arse chopped off for sale by a guy from perth , but he doesn't get on here very often (i think he works in the mines or something) , might pay to harass him :ninja:
pic for homer:
(i'm guessing it doesn't look like this any more?)
Edited by toffy
eddie.
regards to roof lining - don't fk around with that and trying to track down some 20 year old hack.
rip out the old lining, keep it in tact as much as possible, scrub the old foam off using a brush and pull all plastic trims off as much as possible
take it to a marine trimmer. tell him what fabric you want.. i suggest a grey flock. he'll cut it to size PROBABLY using your old lining, or if it's not even there then he should make one up..
shouldn't cost more than a hundred bucks
ou should see my soarer.. that things has been a bloody effort and a half!!!
things i've have to do for registration:
change out CCFL headlights return to OEM ones
change out CCFL highbeams return to OEM ones
remove "dolce horn" (japanese bippu train horn)
remove headlight HID kit. replace with halogen globes
remove highbeam HID kit. replace with halogen globes(why put HID highbeams!!!! bloody japs..)
remover blitz ultra white parklight kit - only to find out that these park lights are mounted to a full strobe light kit.
and heaps more
oh
remove the perspex glowing panel which lights the japanese license plate from behind.
far out.
lucky this stuff is all worth it!
yeah? sharing is caring :D , no one will post roof lining which is the only thing i need now :( . fiberglass is pretty easy to repair btw but very messy (read: itchy) to sand , what is he planning on doing with the car? (i.e pig spec , show car etc) if he wants to go for a show car look it might pay to try your local nissan dealer for new stuff (long shot) because most parts floating about these days are pretty average . p.s pics!
i just received mine in the mail yesterday :P
all i can say now is my interior is complete
OT: i have red door trims if your interested, in in S.A. though ....
    • This is the GTR fuel pump. Yellow shows 12V, orange shows earth. The ECU provides the earth to activate the fuel pump relay. The ECU side of teh relay will pull low when the ECU activates. This is the RB20 fuel pump. Almost the same, but a little simpler. You can see I indicated (above) where the 12V line goes down to the RB20 diagram on the overall diagram, whch shows both RB26 and RB20. This is where I show it coming in on the RB20 diagram below. You can see that the dropping resistor is handled differently. When the fuel pump control is not providing earth to the pump, the pump earths through the dropping resistor and thus runs at lower voltage (some is wasted over the resistor) and runs slower. I showed that "not 12V and not quite earth" portion of the wiring in a paler orange. The rest of the wiring that I did not colour on that little section below the pump would be orange when the fuel pump coontroller is providing earth. This drop is handled inside the fuel pump controller in the GTR. Regardless, you can see where 12V is supposed to be, where earth is supposed to be. The key on prime is via the ECU providing the pump for only a few seconds the switching off. You should be able to see that happen.
    • Yeah so when you turn key to IGN the fuel pump should run for a few seconds. If you find the fuel pump relay (and have a multimeter, and a second person) to can check the relay inputs.  One trigger pin should be either fully earthed  The other trigger pin should get 12v from the ECU for say 3 seconds when you turn key to IGN, and at all times that key is at START (note, I said this from memory, it may be the other way around, ie one pin always has IGN 12v and the earth has continuity to earth when you turn the key) One Pin should have a good battery voltage The last pin goes to the fuel pump + Also note that if the power to the relay is good, and the relay is working, it is worth checking the pump has a good earth too. There is a computer in the standard system that increases the earth resistance to slow down the pump when not required, pretty old school and it may have failed
    • All this talk about fuel and fancy ECUs, meanwhile my poor old R32 has neither.... When the ignition is turned on, should there be power running o the fuel pump constantly or just for the few seconds it usually takes to prime the pump? About to go have another look at it, have watched some YouTube vids on how to use a  multimeter and looked at some wiring diagrams but really have NFI what I'm looking for because electricity is invisible
    • Yuh....but weren't all the supertourers, except maybe the Audis, FWD? I don't recall any of the others being AWD.
    • They ran them in Oz Super Tourers too https://www.supertouringregister.com/register/vehicle/212/ (I'm so old I remember racing with Matthew Fox) They ran them in Oz Super Tourers too https://www.supertouringregister.com/register/vehicle/212/ (I'm so old I remember racing with Matthew Fox)
