ok I get it. just bypasses the cooler until up to temp,
shit that means redoing all the braided lines, what a bitch of a job, so tight in there..
IF I could just buy the relocator blocks separately, is the thermostat in the filter block or the one bolted to the block?? either way it would be easier to just change out one of them.. anyone know who might sell them individually ?
thinking about it, it must be in the one on the block so that it still circulates oil until it opens up and goes to the cooler, filter relocator etc? right?
no it's in the remote filter mount. when cold oil travels from block to filter mount, through filter and then returns (through the closed stat) back to the block. when up to temp oil will flow from block to remote filter, through filter, into oil stat (now open) and on to oil cooler, it then flows back to oil stat and then back to block. no ports in the oil stat are blocked off or used for gauges. you need all 4 ports.
link to mocal ones. you want the OT2. OT1 is for toy cars...
http://www.thinkauto.com/oilstatcolour.htm
top right in this picture.
again though. if you want to do it simply and easily just buy a jap kit that has the oil stat built into the remote filter mount. you can easily tell them as they'll have 4 ports on the filter mount (from block, to block, from cooler, to cooler) instead of just 2.
    • No need to replace the cover if it is still intact (not worn through). It would be worth checking the balancer for matching marks on the rear, but I'd assume the balancer was loose at some stage. The cam timing marks look fine, once you put the new belt on you can only be right or a full tooth out
    • Disconnecting rods! must have been an unpleasant surprise...
    • So been ocd with timing mark but checked from few angle and seems both cam are on and crank is matching as well to the slot on sump and crank pully   i noticed crankshaft cover has been robbed as per attached pic. Any ideas why? Could my balancer or harmonic be on its way out? should I replace the cover? https://ibb.co/ZR1JFYRR
    • So now doing the change and first time dealing with rb so little nervous giving engine power and potential for screwing it up When you align all marks and then remove crank bolt, timing move little I assume you can put the bolt back in once you have removed the pully to get timing to where you want?   here is pic of my both intake and exchust cam aligned, depending on angle you look they seem to be either aligned or a half tooth or so out. Any thoughts? Should you angle your face and look at each mark that way as if looking straight rather than from above as it can be misleading   <a href="https://ibb.co/ZpnhcvbF"><img src="https://i.ibb.co/HfWrGR9b/IMG-4447.jpg" alt="IMG-4447" border="0"></a> <a href="https://ibb.co/4wm2wn4q"><img src="https://i.ibb.co/JWBqWwr1/IMG-4445.jpg" alt="IMG-4445" border="0"></a>   https://ibb.co/ZpnhcvbF https://ibb.co/4wm2wn4q
    • Thanks for the reply @GTSBoy Haven't really thought of that yet, but you are right. If the hose was damaged it should be absolutely pissing by now. I'll put some heat sleeve around it for good measure since I'm already removing the line anyway.  Maybe I'll put on some of the stock hardlines if I ever fully remove the turbos again. Maybe when T51R modding the compressor housings? Might be a fun mod on GT28s for that "fake single turbo" effect.
