ITEM: Rb26 PFC, rb25/26 harness prewired for s14, coilpacks many xtras!!
PRICE: 1500
SHIPPING: yes, anywhere
DESCRIPTION:
Ok i am selling a complete Rb26 / 25 Electrical solution for a steal of a price. First A near new Apexi Power FC D Jetro, with the handcommander that has been modified to have a blue backlight instead of the green one(baller...). Next is a complete Rb26 Harness prewired for a S14, i am including with this a set of working coilpacks, the injector resistor wired into the harness, and an external rpm activated switch so this harness can be used on a rb25det. There is also a Z32 PTU (ignitor) pre wired in so no need to get costly ignitors anymore, and finally a Q45 MAF which is an upgrade to the stock one. This harness is plug and play for any s14. Finally as an xtra goodie i will throw in a HKS DLI I harness, so if can get a HKS DLI all your ignition problems will be solved regardless of HP(btw the supplied coils work 100%).
To Simplify all of that. Its a Harness that will work on rb25 or 26, with an upgraded AFM, ignitor, and resitor and included coil packs. An Apexi PFC Standalone with modified hand commander. An HKS DLI HARNESS (not actual DLI but useful if u get one), and finally as a last bit of good faith i will unclude two Rb26 02 Sensors for the harness.
I was currently using this on my RB25 with topfeed inj but i changed harness since i tucked my new one.
This is a steal i am only asking 1500 for all of that, the standalone is worth 1000 alone and the labor on harness is 400 not including the actual harness ( which is around 400), and i am giving you coils, dli harness, q45 afm, 02 sensors, and prewired ignitor upgrade
i am not really trying to part out, i am OBO on price and open to trades, but i wont be underhanded, if i trade i need kouki front end parts (lights, hood, fenders, radiator support, bumper support, radiator) or some rims that look nice and clear z32 front and rear brakes.
i can be reached at 732 552 1467 or email [email protected]
i live in NJ, and i will cover the shipping cost. i have an apexi avcr i will throw in the mix too for 200 dollers if you buy the entire setup... the avcr is in tip top shape and all parts included its in near mint condition !!! (this cost 400 new !!!)
CONTACT INFORMATION:
EMAIL: [email protected]
AIM: stricnynel0s
PAYMENT OPTIONS: Any, or Trades for S14 Kouki Parts or Rims
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
