In the final stages of finalising a contract to move back overseas with work, which means some parts I have in storage will be up for sale, if i get the right price then will part with them as they are costing me $210 a month to have in store (along with some furniture etc)
- Brand new Tomei RB24 pistons. Increase bore to 82mm. Part No. 1112820112. Asking $1670
- Tomei RB20DET / VG30DETT Valve Springs for Procams or 10.35mm lift cams. Asking $380
- Tomei RB20/25/VG30 Solid Lifters and Tomei retainers for use with Procams (used) - $450
- Tomei Procams 10.35mm lift. Not sure if they are 260 or 270 duration. They come with a set of Tomei solid lifters. All are currently at engine machinest as they came out of an RB24 that suffered a catastrophic big end failure and upon receipt there were signs that the head had been starved of oil and cams are scored. Machinist is confirming duration and that they can be tidied up and used. Take cams as is with lifters for $300 or wait until I have had them inspected and repaired as/if required
- Also have a new set of Apexi RB26 titanium retainers. They are heavier then i expected so surprised that they are titanium. They are Apexi and in the catalogue I have access to Apexi only list titanium RB26 retainers
The Tomei lifters are perfect for RB25/30 builds that want to run the high lift Procams, though the valve springs are not suitable for the RB25 head.
- Also have an R32 RB25 crank that has been balanced and oil drive collar installed. Comes with a set of std, balanced RB26 rods to suit. Asking $1000 bor crank and rods
If you want a number of the components then will do a better price for a number of components. All you need to build a tough RB24 is here, pistons, rods, crank, valve springs, reatiners and lifters. Just chose the duration cam you want to run.
Apart from the cams the gear is either new or in good condition ready to go. I have been pulling the bits together for a tough RB24 for a long time, but just cant see it happening anytime soon.
Also have a Greddy Type R gate that has only seen a few hundred kms of dyno tuning and an RB26 block with near new N1 oil pump and water pump I need out of the way, so offers?
  • 5 months later...
  • 3 weeks later...
Any offers on the Tomei RB24 pistons? If someone wants to take the complete RB26 bottom end of me with the pistons, Poncams, valvesprings and lifters then happy to discuss reasonable offers.
The RB26 bottom end is in perfect health other then a ring on one of the N1 pistons. So the oil pumps, water pump, balanced crank with oil drive and rods etc are all less then 5,000kms old (well under) from a rebuild. So with the bits from the 26 bottom end, add to the Tomei pistons, throw in the 256/8.5mm cams and springs and you will have the basis of a tough 2.4L!
  • 6 months later...
The cams are gone. I want $1000 for the RB26 bottom end, mainly due to the fact it has oil pump, water pump, sump etc and near new N1 pistons etc .
If someone wants my RB20 256 Poncams I still have those. $800. They were usd for dyno purposes only.
Engine is in Moorabbin
    • Doing a refresh of my 33 and can see a few websites stating they sell the entire main carpet for our cars, but they all have generic photos which is fine, i understand they are custom made to order.  Just seeing if anyone has got it done or had any experience with this, as i would only want to do it if the fit and finish was as good as oem https://carmatsdirect.com.au/products/moulded-carpet-or-vinyl-for-nissan-skyline-r33-1993-1998-coupe https://knoxautocarpets.com.au/moulded-carpets/nissan/skyline/skyline-r-33-1993-1998/
    • Any plans for E85? If so, add flex fuel sensor.   I'd probably add in the sensors I mentioned above if the Link will support using them for engine protection. With water pressure, you need to be able to effectively set it that "If temp > X, and pressure = atmospheric, shutdown" as at running temp, you should be able to read pressure in the cooling system. If pressure suddenly disappears, it means the water went some where, and this is a quicker reaction than waiting on water temp to go up (Which, can take a little longer than you'd like, considering it now has to wait for hot air to heat it up) Oil pressure, Oil temp, both would be on my list too if you're looking to add sensors. Wideband O2. And at least one EGT sensor. If you're feeling deluxe, put in individual runner EGTs. Single EGT sensor is more so forget about a specific number, get used to "What is normal EGTs", and then keep an eye on it, if it starts going away from "normal" it's a sign something is wrong (Also, things like the tune can still start going out of spec, but EGTs may not show it, for example one injector starts running leaning, so ECU richens everything up, now 5 out of 6 cylinders are rich, and running cool, with one cylinder lean and running hotter, so it's not perfect) Then there is your other things to look at non sensor related, but you may have already done, or have underway, and that would be things like building a sump for more oil, and better oil control under high G-Forces (Cornering, brakes, acceleration). Basically, the above is worth looking/thinking about, if the ECU can do protective stuff with it, and you continue to use it how you are (Drive it to the track, thrash it, drive home, repeat once every 3 to 4 months)
    • Can also confirm these work a treat for most balljoints and bushes. If you have access to a big rattle gun, they make the job so much easier and quicker, compared to using a socket wrench or shifter on the c-clamp 馃憤
    • Its sort of street but got used for circuit sprints on account of I never drive it on the road because I dont have the time to spare. So it usage was sits around for months at a time then gets driven either 50 or 250 kms to the track followed by 20 laps followed by 50 or 250kms home followed by stuck in the shed until next time. So yeah neither fish nor fowl. Just dont want to break it on the track as a preference. Hence the fairly short sensor/mod list. Probably more worried about it pinging itself to destruction more so than anything oil related.
    • My thing I'd be doing, is pulling it out, and just getting the tune cleaned up for now. Before that even happens, checking over everything, like vac hoses, fuel hoses, etc. No point dropping thousands on sensors if the moment you start it back up all the oil leaks out, or it has massive vacuum leaks etc.   But really, to know what to do, depends on what your use case is. Hard core track car? Throw most sensors available at it. Street car, I'd probably just run oil pressure, oil temps, water pressure, water temp, probably fuel pressure too. I don't know exactly what the Link can handle and do with those though. And if it's mainly just to cruise the streets, rather than mountain runs, you can probably skip most of the above if you've already got them in as gauges and warning lights.   PS, inb4 "sell it and buy a modern sportscar"
