Hey guys,
I'm having a problem with holding boost properly with my garrett 3076r...its ramping up to 21psi but then tapering off to 18psi above 5000rpm...i'd ideally like to have it hold 21psi across the rev range...
Setup is a little different though...
Toyota Supra
2JZ-GTE
Custom low mount manifold
Garrett 3076R 56T 0.82 IW with Garrett big can 18psi actuator (preload is set right and its achieving 17-18psi with the boost controller off)
4" intake pipe
Sard 280LPH fuel pump
FMIC
3" exhaust
PFC
AVCR
I've had the car on the dyno twice trying to get proper boost control but i can't stop the boost from falling off...the rb30det boys suggested using the 18psi actuator which i've got and its still not doing it...the boost curve looks almost idetical with the old smaller 14psi actuator and the bigger 18psi one...its still ramping up very well and 20psi is achieved by about 3300rpm...but then it justs falls off by 5000+rpm...i've tried tweaking the AVCR with numerous different settings and all it does is cause boost to ramp higher (23-25psi) before falling back to 18psi again...
Does anyone have any input on this...note that external wastegate is not a valid response... :P
https://www.sau.com.au/forums/topic/342146-gt3076r-not-holding-boost/
  • Replies 62
Posted Images
Why do I want to derail this thread SO BADLY?
Looks like your Genuine Garrett item is no better than the Hypergear item you spent so much time badmouthing.
Although to add a relevant response, since I haven't seen results of this turbo at that boost on a 3L....what are the chances it's either running out of puff, or that the exhaust flow from 3L engine against the wastegate on top of the boost pressure against the actuator are causing it to not hold closed as much as desired? I know that last situation isn't likely, but perhaps it just can't flow what your engine wants to swallow.
Looks like your Genuine Garrett item is a lot better than the Hypergear item you spent so much time badmouthing.
Fixed. We know the GT3076Rs spool faster than a 300+kw Hypergear turbo, and here it is holding similar boost on a 2JZGTE as what the Hypergear does on an RB25... its clearly able to pump some air to do that.
I'd say however that at that boost level its a good chance that its just maxing out, its not that large a turbo for a decent flowing 3litre - how much power are you getting out of it at that boost level?
I fail to see how that's any more correct than my obvious troll post, given his above posted results.
STATUS posted a Hypergear vs 3071R graph a few days ago which would say different. They were for all intensive purposes identical spool... Unless you are going to claim a 3076R will spool faster than a 3071R?
Edited by SimonR32
:ninja: I give you some advise either way.
I've managed to hold 22psi on a RB30det VL, of a customer's car. Needs custom made twin spring actuator with gate controller. If you really want to stick with Garrett Actuators try: 446131-23 .
If that doesn't work, send in your turbine housing for modifications. Which I will charge you a million dollars :) .
Trozzle - I added 2c in regards to why it COULD be boost dropping... when I chose a GT3076R for my RB25 I was aiming for a setup which could flow efficiently enough to push around 22psi of boost into a 2.5litre up to 7000rpm without being silly about it. To do the same on a 3litre I'd personally be looking at using something more like a GT3582R, so really I'd expect the required solenoid duty cycle to maintain 22psi or so in the higher revs to go WAY up when used on a 3litre in higher revs as IMHO the turbo will start hitting its flow limits.
Other obvious things to check would be if there are any leaks, either exhaust or intake side. Also, I am not convinced on AVC-Rs at all... when I had the softer actuator on mine I couldn't convince it to bring it anywhere near strong enough onto full boost, I had to upgrade to an 18psi big can unit.
Its doing the same things the Hypergear turbos which were used to crack 300kw were doing on RB25s... if you don't quite understand that "boost" isn't a universal thing, what this means is that if you put the 300kw Hypergear turbo onto the larger 2JZGTE and this IS what the problem is - there is a good chance you'd see full boost reached slightly later than the GT3076R, but then boost dropping earlier again and a net result of less hp in the top end.
I gave up following the Hypergear threads after there were "not all being equal" factors used too consistantly which could skew things to make it seem the Hypergear was better in comparison than it really was, so not sure exactly what was shown and as such can't really comment. I'm not one eyed or stupid and also don't try and pull the wool over peoples eyes so don't see why you are implying I would suggest a GT3076R would spool better than a GT3071R, keep that brush on the people who do that kind of thing.
To all the haters...you can say whatever you want regarding this...i've said my piece the other turbos and i stand by it...feel free to keep spouting crap...i've long stood by the motto that you should only dish it out if you can take it...
I chose this turbo because other RB30DET members on here have gotten good results on their cars with this setup...and with the 18psi garrett actuator too...yes the 3076R is a tad small for a 3L...i know that...but i chose it because peak power wasn't the aim...maximum response was the aim with 300rwkw in mind...and it does that...no complaints there...also...i wanted to be the first to do a low mount single setup in victoria just to prove it could be done...and i've proven it...have a look in the RB30 thread for some examples...i'm staying out of comparisons between rb25s here as a 2JZ is a whole different kettle of fish...
Maybe it does? Garrett 3076r: 18psi 3000rpm
Its also not been equal that you are running on a "NZ dyno" with all the enchantments for better response. This also made you the most responsive 3076R .82 int gate through out Australia. Far better then some with cam gears and external gates. Run that on Status dyno and see what happens.
Since we're all joking here...if i had a million dollars...i'd start a turbo highflow service and claim a gazzzillion KW at 1000rpm...
But seriously...if you can find people with 2Js for you to trial your constant R&D and pulling off and replacing turbos on a contant basis and get the results i'm after then i might consider your products...if not...then nah...
If peak power isn't your aim, why are you complaining about boost dropping off in the top end? Honest question.
Always going to happen with that size turbine housing on a 3L.
Well...peak power isn't the aim...area under the curve is the aim...and with consistant boost pressure i'd get more area...
The turbine housing can do it...proven here in this thread...http://www.skylinesaustralia.com/forums/Gt....html&st=20
So the issue is more likely to lie with my setup...and not my turbo...which some people seem to be wishing for... :)
Seriously I can really make that work and hold it at what ever "high" settings you want it to set it. even at 24psi as long as the turbo it self can take it (assume engine's won't have issues).
    • Breather for it. If it's anything like the GTRs it should run up to the top of a bellhousing bolt.
    • What basics? With these OBD1 ECUs it's not like the ECU will give you any real clues, it's not really doing any sanity checking of sensors/sensor data. My experience is actually a lot of sensors tend to be the source of the issue first and foremost, and checking everything gives you a direction to investigate. MAF/O2/STFT/LTFT should all kind of make sense. You can try little tricks of the trade like tapping the MAFs to see if it triggers a stumble, things like that. But once you've done a compression test knowing whether you have an air leak or fuel delivery problem is kind of hard to narrow down without sensor data. And you don't really know if all your sensors are making sense unless you can interrogate the ECU directly about what it's seeing for sensor data.
    • Absolutely this. Yes, except not vacuum hose. Something oil/fuel safe is a better idea.
    • Like a Stagea, but not as cool! Hope you have enough garage space for this, or is something going to leave to make way for it?
    • The new project has arrived. I have wanted one of these for such a long time, well before that meathead Clarkson drove one in Africa. I really wanted an E34 but I have some medical issues that mean I *really* can't bump my head and the lack of airbags in the E34 made it just too big of a risk.  I don't know why I've always liked these older touring BMW's to be honest, but man I love this car. She's been pretty well maintained for her 243k's with what appears to be only a single oil leak at the oil filter housing gasket. It has a bunch of updates including later model bumper and headlights, 7 series billion-way adjustable seats and it came with a few spares and another set of wheels with legal tyres. I got a unregistered car permit from the RTA and drove it back from Canberra on Saturday.                   First cab off the rank is cleaning it up for blue slip. I dont know how picky they'll be but I figured I'd clean the headlights, fix the oil filter housing gasket, replace the speed sensors (throwing errors) and swap the OE wheels (the M Sport wheels have a big chunk out of one of the tyres.) I also need to replace all 6 gas struts - 2 for bonnet, 2 for hatch and 2 for hatch glass. The car tries to eat me whenever i open any of these. My plan for this car; Ultimately, this is a budget car. I can't afford to throw lots at it and its because I have another car that I got this, if something breaks its no big deal. I will just maintain and repair it really. But eventually I want to do a manual conversion. It actually looks pretty straight forward for E39's and the trickiest part will be sourcing the parts.  I do need to replace some suspension arms or bushes because wow, she's a floaty old girl. She's also fantastically slow. Like really, really slow. When pulling back out on to the freeway on Sat after a quick pull over I needed to wait until no cars were visible before going.  Oh, and the guy I bought it from had a gorgeous R31 GTS-X in the garage.
