Hya,
Need some advice plz.....
I was driving on the freeway (stop start traffic)
and my car died.
Once it cooled down a little it was okay
and I managed to get going again.
It's happened a couple of times now when it's a warm
day and the car heats up, any ideas what this could be??
Is it a sensor that's cutting out once the car gets too hot?
Bloody bastard!!
https://www.sau.com.au/forums/topic/342210-car-troubles-help/
the stock ecu will back out timing when water temp goes up but it certainly wouldnt kill the engine like you described, just a touch sluggish
when you see the issue what does the water temp guage look like on the dash and are there any red warning lights on - these would be dead obvious but just in case
any do you have nissan consult? if you could get that or borrow it you can run a diag on all the stock sensors and even see what the ECU is picking up water temp
this would tell you the sensor is toast (it could be) or out of range etc
The water temp stays midway, maybe I should get a
water temp gauge just in case......
What's a Nissan consult? :) lol
This is the Pulsar, everythings pretty much stock
but the turbo upgrade bits.....
But yeah, the car died - when I tried to restart it would
rev to 1k then just die out, even if I tried to accelerate.
I let it sit for 5 mins then she was fine again till I got home.
Thanx for the help ;)
Yea, the technical reason is that a failing fuel pump overheats when not in motion. When you rev your car, the petrol actually cools the pump. When it heats up it dies.
Thats one possibility of course, if you havent changed it for 100kkms, or have no idea when it was last changed, you may aswell do it. Get the fuel filter done while you're at it.
    • Is the 650rpm idle on the rb25det neo for stock cars only? I've never had my car before and after tuning it to idle at 650rpm when cold. Always idle's cold around 1100rpm, and then drops to about 900-950rpm. I've heard the r33 gtst's idle there.
    • Series 1 RB25DET 5 speed gearbox, push type, 1st and 2nd gear syncros worn, may need bearings. Comes with quick shift, Tomei gear knob, release fork, bearing carrier, master and slave cylinder. $850. Cusco Super Single clutch,assembly, 225mm, used, comes with a Direct Clutch solid centre 5 puck ceramic clutch plate. $290. RB26 cams used, excellent condition. $280. HDI GT2 intercooler, excellent condition, has 3 inch piping welded to inlet and outlet. $250. All items located in South Eastern Melbourne. Please PM me if interested.
    • Hi all, I’m currently running a str pipe hi low hks exhaust and downpipe. Was wondering if I change out muffler to a titanium one will it change the sound of the exhaust? Plus I have always liked the look of the titanium pipes … anyone have recommendations to one?    side note already have titanium intake pipes.
    • I looked up my other car that is a R33 GTST series 1.5. Anyone able to confirm what a Aero Form Bumper is?     (1G) 2 Door Coupe; (2GK + 11V) RB25DET; (4B) 2WD HICAS; (7F) 5 Speed Manual; (14G) Super Fine Hard Coat; (15U) Large Rear Spoiler + Aero Form Bumper + Rear Wiper (Aero Selection)
    • Ha ha, all good! I've almost caved in and realised I'm buying one.  I know myself well enough by now that I will start chasing ADHD butterflies half way through building it and not finish it so I'm better off spending the extra money buying one instead of making one just so I can get into straight away.  I would very much enjoy making one as fabrication is probably a strength and definitely a passion but I don't want that to be at the detriment to the car I'm ultimately building it for! There's some pretty good ones around for ~$1100 at the moment so I think I'll just go that way.  At the end I sell it or as mentioned, get another project to make further use of it! Thanks gents.
