hey guys, i have a r32 gtr which has been running a bit weird latetly.
at first it was occasionally about once a week, but now its getting more common, like at least everytime i drive it.
cold mornings its fine, once it starts warming up is when the problem occurs.
i first noticed it when i parked my car, let the turbo timer do its thing then just as i was walking away it started spluttering at idle, did that for 5 seconds then regained normal idle. it also did this while waiting at a set of traffice lights (even while i was rolling upto them) blip the throttle a few times and it sometimes goes back to normal idle.
why is it doin this?? its VERY annoying, ive even swapped the idle position sensor and still had the same problem.
also say im just driving down the road, it will even splutter (like its out of fuel?) nd have no response on throttle. then as im trying to accelerate in gear (while still doin speed limit, slowly gettin slower) it sounds like it misfires. sometimes this goes on for 5 mins and i cant even drive it, and other times its over in 10 seconds? then back to prefectly normal.
even if you hold your foot in the same spot on the accelerator pedal, it will cut out, accelerate, cut out etc..
i seriously have no idea whats wrong with it.. fuel pump? something to do with idle control? but that wont help the problem while at speed? it could be 2 different problems.
if anyone could help that would be GREATLY appreciated
Cheers.
Also check the cam angle sensor, you can just unbolt it and have a look. Mine had broken teeth causing this, replaced with $100 second hand CAS and worked fine.
^ When I changed the turbos it started fine, misfired after 20 mins, started feeling like you were turning the ignition on/off etc. I checked afm's, cleaned injectors, filter, ignition module, etc. Replaced the CAS with a mates, still no go, changed back to mine, worked fine. Turned out the plug for the CAS just needed a wiggle/twist. Dunno if your prob is the same but,
Coils: I'd unplug one coil to see if it sounds different/makes it worse. Check each coil, takes but a few mins.
AFM: I'd simply get AFM cleaner and clean it anyways, if it's the stock one. Few bucks, worth it.
CAS: Wiggle the plug/Unplug and reseat. Borrow one from a friend before spending money on replacement.
Fuel Filter: Cheap, but nasty to replace if you have big hands.
Plugs: How old?
cheers guys, its hard to diagnose cos its not always happening, just sometimes desides to do it.
wiggled/unplugged the CAS - same
its not the coils either, checked them
plugs are probly due for a change, but that would make it run shit all the time? or not?
but when i un-plugged the AFM it started to run shitty, exactly like the problem i explained above.. then after a few seconds it regains idle but wont rev over a few thousand revs, (not crisp anyway)
is there any sort of tests for AFM?? to see if they working correctly? or faulty?
thanks, will try to find an igniter and see how it goes.
but how do you know if the AFMs are dodgy? any way of telling? or just have to swap nd see?
just swapped the AFMs with another working pair from another GTR, seems to be working perfectly fine atm.
hopefully this is the problem! nothing worse than not knowing what the hell is wrong, hate guess work haha
need to find a set of AFMs now, or find out which one was faulty if not both.
thanks alot guys!
Cheers.
thanks alot guys!
Cheers.
Id replace both. If you do try to buy a set of nismo ones, they are more expensive but have the same characteristics of a Z32 meter which is good if you make some more serious mods to the motor.
Yeh I was looking at some nismo ones, still not sure yet.. Either quick and cheaper fix with STD ones or upgrade to z32 or nismo and get it re tuned. I do wana upgrade the engine later down the track tho, but my pockets arnt deep enough at the moment hah
May go for the cheap fix first then upgrade a bit later on
Cheers mate
fair enough.. looks serious! haha
i just got HKS pods, lookin to change to the Apexi setup.. will get onto nismo ones soon!
but in the meantime will std AFMs from a Aus delivered GTR work on an imported GTR? i was just wondering if they are diff?? probs a stupid question but am just curious?
cheers
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
    • No worries at all 🫡 I think the most satisfying things to make are the little bits that are just impossible to find or they're no longer manufactured. Generally I always try to replace parts with OEM wherever possible. This little project is also great because it'll never see the light of day, but strengthen these brackets so it's not just relying on the little standard screws in the headlight plastic. As soon as I saw the standard brackets and screws I thought, "well I'm not going to install with just the screws, the plastic tabs will just snap off". It's crazy how expensive everything has become yeah. But I suppose that's supply and demand; granted it's a lot easier to get brand new genuine parts these days which is fantastic 😊, I don't have to get totally reamed at the local Nissan dealer ha ha We sure are lucky we have all these manufacturers making parts these days, a few really great Australian companies too like Platinum Racing Products and Fit Mint Automotive, what a time to be alive ❤️ . I've got my eye on the RB26 head by PRP as mine has a very fine hairline crack, so that'll need to be addressed some time in the future. If you have any requests or odd things to make feel free to let me know and I can have a crack at making replacement parts ✌️
    • Thanks for sharing this, and BTW if your headlights are in good condition they are worth thousands....you might want to consider replacing them with brand new LED ones like this (https://www.nengun.com/78works/full-led-headlights-r32-skyline) and making enough profit to buy a house in Sydney
    • I'm not sure what sort of shops are nearby, but I'd expect any reasonable exhaust shop could put a cat in it that will not restrict the power that engine makes. Otherwise, if you want to remove it, short lengths that replace the cat are readily available online, search for "de-cat pipes" or "test pipes"
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
