hey guys, i have a r32 gtr which has been running a bit weird latetly.
at first it was occasionally about once a week, but now its getting more common, like at least everytime i drive it.
cold mornings its fine, once it starts warming up is when the problem occurs.
i first noticed it when i parked my car, let the turbo timer do its thing then just as i was walking away it started spluttering at idle, did that for 5 seconds then regained normal idle. it also did this while waiting at a set of traffice lights (even while i was rolling upto them) blip the throttle a few times and it sometimes goes back to normal idle.
why is it doin this?? its VERY annoying, ive even swapped the idle position sensor and still had the same problem.
also say im just driving down the road, it will even splutter (like its out of fuel?) nd have no response on throttle. then as im trying to accelerate in gear (while still doin speed limit, slowly gettin slower) it sounds like it misfires. sometimes this goes on for 5 mins and i cant even drive it, and other times its over in 10 seconds? then back to prefectly normal.
even if you hold your foot in the same spot on the accelerator pedal, it will cut out, accelerate, cut out etc..
i seriously have no idea whats wrong with it.. fuel pump? something to do with idle control? but that wont help the problem while at speed? it could be 2 different problems.
if anyone could help that would be GREATLY appreciated
Cheers.
Also check the cam angle sensor, you can just unbolt it and have a look. Mine had broken teeth causing this, replaced with $100 second hand CAS and worked fine.
^ When I changed the turbos it started fine, misfired after 20 mins, started feeling like you were turning the ignition on/off etc. I checked afm's, cleaned injectors, filter, ignition module, etc. Replaced the CAS with a mates, still no go, changed back to mine, worked fine. Turned out the plug for the CAS just needed a wiggle/twist. Dunno if your prob is the same but,
Coils: I'd unplug one coil to see if it sounds different/makes it worse. Check each coil, takes but a few mins.
AFM: I'd simply get AFM cleaner and clean it anyways, if it's the stock one. Few bucks, worth it.
CAS: Wiggle the plug/Unplug and reseat. Borrow one from a friend before spending money on replacement.
Fuel Filter: Cheap, but nasty to replace if you have big hands.
Plugs: How old?
cheers guys, its hard to diagnose cos its not always happening, just sometimes desides to do it.
wiggled/unplugged the CAS - same
its not the coils either, checked them
plugs are probly due for a change, but that would make it run shit all the time? or not?
but when i un-plugged the AFM it started to run shitty, exactly like the problem i explained above.. then after a few seconds it regains idle but wont rev over a few thousand revs, (not crisp anyway)
is there any sort of tests for AFM?? to see if they working correctly? or faulty?
thanks, will try to find an igniter and see how it goes.
but how do you know if the AFMs are dodgy? any way of telling? or just have to swap nd see?
just swapped the AFMs with another working pair from another GTR, seems to be working perfectly fine atm.
hopefully this is the problem! nothing worse than not knowing what the hell is wrong, hate guess work haha
need to find a set of AFMs now, or find out which one was faulty if not both.
thanks alot guys!
Cheers.
thanks alot guys!
Cheers.
Id replace both. If you do try to buy a set of nismo ones, they are more expensive but have the same characteristics of a Z32 meter which is good if you make some more serious mods to the motor.
Yeh I was looking at some nismo ones, still not sure yet.. Either quick and cheaper fix with STD ones or upgrade to z32 or nismo and get it re tuned. I do wana upgrade the engine later down the track tho, but my pockets arnt deep enough at the moment hah
May go for the cheap fix first then upgrade a bit later on
Cheers mate
fair enough.. looks serious! haha
i just got HKS pods, lookin to change to the Apexi setup.. will get onto nismo ones soon!
but in the meantime will std AFMs from a Aus delivered GTR work on an imported GTR? i was just wondering if they are diff?? probs a stupid question but am just curious?
cheers
    • I removed the IACV, cleaned it and reinstalled.  I found a video on youtube that helped with the whole process, the guy then said the idle needed to be set, so the process was to get the vehicle up to operating temperature, unplug the TPS, set the idle screw in the IACV so the RPMs were around 600, then plug the TPS back in.  After I reinstalled the IACV, the car started (because, it was a cold start), once it warmed up, the car died, I adjusted the idle screw to see if that helped anything, it did not, I had to wait about 3-5 minutes, then the car would start back up. Only to shortly cut out, and only crank.  I loosened the TPS to see if adjusting that would do anything, and when I would rotate the sensor clockwise, there was a humming noise, but it would go away when I got the sensor in the horizontal position.  It only made the hum noise with the key on.  What do you guys think? 20250414_172604.mp4
    • Quick update.  The engine grounding strap was replaced, the engine is now happily running.  Tested the voltage drop before replacing the strap, was about 1.2ish volts down between engine to battery, chassis to battery. With the new grounding strap, pretty much no voltage drop at all.
    • I was chatting with an ex SAU person who is involved in chooning euros now. He was saying the factory cars like Audi VW etc have something like 2000 tables that the ECU uses for getting everything "just right". Compare that back to any aftermarket ECU, and you'd be hard pressed to surpass 50 lookup tables. Even the Ford Barra engine has a few hundred lookup tables to run it (and they're still working some tables out too!)
    • Grab a temp probe, and probe each exhaust inlet runner with it sitting idling. Each one should be pretty darn close to the same temp. If you've got some reading higher or lower than the others, it's likely either air flow isn't equal, or your injectors aren't equal to each other.   The other things to check, is from the wiring changes that were made, were any earth's or grounds moved/changed.   Lastly, for the strut brace issue. It's not perfect, but can you get away with slipping a washer or two under the strut brace to raise it, and it still clean the bonnet? If you can, work out the height you need, that the motor can't torque up into, and get a spacer made for each side.
