*yawn* tomei is the way to a broken bank balance, and this guy doesn't have all the money in the world.
IMO you are best to get a set of CP or Wiseco pistsons mate for what you are trying to build at present.
Best compromise between price and quality and have been proven in a ridiculous number of 350-400rwkw+ setups.
i got my TOMEI pistons for 1600 if that makes you feel better
Being that you can get CP's outta the states for under 1000 bucks.
Its kind of a waste spending 700 more on "allegedly" better pistons, yet no real evidence they are better than anything else on the market.
  • 4 months later...
I'm using them in a 26/30 with no problem.
They were more expensive than most others when I bought them a while back. Supertech make some high end ie F1 gear from memory. I agree with what's said above, clearances etc are much more important than the value of picking one piston over another, and the well known brands have all proven themselves.
Edited by Scooby
yeah they are good but like dave said the jap stuff is not just pretty packaging. the tomei pistons in my engine are so quiet you wouldn't know it's forged. zero piston slap even when stone cold and they can handle plenty of power like any other piston. I do agree they are not the best value though being quite expensive compared to other chinese and US options but there are certainly not a waste of money.
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
