FOR SALE R33 SKYLINE GTST-rego till Feb. 2011
I had planned to use this car as a weekend track car so the interier is partially removed and the a/con has been removed but I have the interier parts in the garage to go with the car, SO, either refit and keep the car on the road or take it as a track car and leave it in its present state.
Mods include-Plazmaman Plenium, Hybrid Front mount intercooler, Turbosmart BOV-plumbed in, Turbosmart E-boost 2 controller, big injectors, pod filter-K & N, Apexi Power Fc hand controller, running 14 pounds of boost atm, CES Racing Systems Turbo back exhaust-screamer pipe ( plumbed in before cat ) Big bore exhaust with cannon 5 in tip. Greddy turbo timer, Boot mount battery set up, Tien Super Street coilovers, staggered wheel sizes-Front 18 x 8 and Rear 18 x 9. Front tyres Toyo R888 225 40 18 semi slicks ( have 2 spares ) Rear tyres 255 35 18 Potenza RE 050 a RFT, also have 4 spare rear tyres-Dunlop Formula W1 275 35 18 semi slicks AND two spare rims 18 x 8 with 235 40 18-6 wheels in total and plenty of rubber. Rear wheel arches rolled. Brakes over hauled-new 5.1 fluid, carbon technology pads in front, front and rear rotors just machined. No ABS. No rear stearing-Hiacs lock bar fitted, clutch fluid replaced with 5.1 fluid, Xeedy Sports tuff Performance clutch, Gates timing belt fitted along with new water pump and cleaned cooling system- 1.1 radiator cap, Blue bulbs fitted to all driving lights/headlights/parkers, engine and gearbox oil changed , well maintained car, reliable and making good power, stock internals ( i think ) , Nismo White dialled instrument panel-320 klm speedo, 11000 rpm tacho showing about 35000 kays HOWEVER the engine has done closer to 125000 kays from new. Strut brace fitted-front, car is very stiff and handles fantastically, power steering fluid replaced. Priced to sell, loaded with power and handling mods, $ 10,000
The car is in Eight Mile Plains/Sunnybank area and can be viewed any time. Contact Stephen at [email protected] or on 041 046 8989. Thanks
https://www.sau.com.au/forums/topic/342213-r33-skyline-gtst/
hey mate, what sort of power are you putting out? got any interior pics?
Most of the inside of the car is in my lounge room. Its a GTR interier.
The car has not been on the dyno since Ive had it this past year as it is running very sweetly and with the Power ups included, its making good power. A nice fast car
How many RWKW was it running when you did have it dynoed.... Looks like it may be rare if those bumpers came like that... I have not seen one like that (in terms of bumpers) are they aftermarket??
    • Maybe but doubt it, when I jacked it up it was creaking in the j arm again. The inners are all good, I inspected them. Remember that also it did fix the problem but temporarily.
    • Could be the other bushes. The inners.
    • Once you lose the adjustable bushes, you have almost no adjustment at the front for anything that matters. You can only wind so master caster at the front, and ~7° is fine. You won't have choice of front camber. If you only have rear camber arms (ie, do not also have adjustable upper tension arms), you shouldn't change their length very much, because you will introduce bump steer. And, you will struggle to find a workshop that will be capable of doing all the adjustment work necessary to simultaneously achieve a decent rear camber number, get the toe right, and minimise bump steer. I would guess there's probably 8 hours of work there. So, stockish rear camber is fine. Although, keep in mind, that stock camber, by number value, does not mean stock arm length when the car is lowered. You will need to lengthen the RUCA to get back to stockish values and that will require the tension arm to be lengthened a little also. Without any other guidance, any change made to the RUCA should have the 2/3 of the same change made on the tension arm. But that is only a rough rule of thumb and the relationship might not remain linear across a wide range of adjustments. And it might not also be as close to minimum bump steer as you could achieve if you did the bump steer measurement and adjustment properly.
    • Well it does have a motor with the same DNA as an Accord V6 motor. The J30A is a successor to the Tiger rice cooker C32A motor found in those cars.
    • FD RX7 I would probably marry if legal R32 GTR is toughest NSX looks like it's made from leftover Prelude and Accord bits
