  • Replies 78
GenesisR32, yep we're in it and another R33 white will be joining me, that's 5 now :cheers:
p.s.
after the mtn run last thursday which i've done a few 360 :headspin: i realized i need new tyres :boobs: , does anyone know where's the best place to get em, like good deals?
springwood crazy clarks sounds good. Like what Nismogirl said, the car park is big and its possibly the best 'neutral' meeting place for both sides.
how about meeting at 8.30pm, have a little social gathering and chit-chat, put names to faces and then finally decide where we all wanna go from there?
each of us will have different suggestions and chances are that we will eventually be split into smaller groups for cruises, mountain runs, home, mistresses :), etc, etc, ... but at least you will still get to choose whatever activities you wanna participate in on your own free will. :)
i got fedrals on my car, they just wore out :) i had 235's though on 18". hard compund and I have to get tyres today as mine ****ed up >=[
I have Khumo 265 35 18"s on the rear, they were about $30 buck dearer than Nankangs.
I've had them since Nov 2002 and they still have heaps of tread!
Got them from Quick Fit at Capalaba.
I might be in this Thursday,.
Agreed, we need somewhere closer to Brisneyland.
As I said, we will only be at the meeting spot to have a chat, then we will probably head home. So don't get cranky at me for organising it and then leaving. Cause people do that quite often when i've said "we are only going to be out for an hour or so"
*scratches head* Yatala is NOT close to the northside. It would be like a 40 minutes drive, and a 10 minutes drive for yous.... I dont really call that fare :S
lol sorry erin, i was doing three things at once when i wrote that...
as said in above post all ideas to mix things up in the name of fairness and fun is great...
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
