Hi guys,
I'm wanting to end some nice rear wing end-caps for my R33 GTR.
So far, I've found two types - one is from JustJaps and the other is from China which is cast in a carbon-fiber looking material.
Which you guys think looks best?
Justjap (full colour): http://www.justjap.com/store/product.php?p...=320&page=2
Chinese replicas (carbon fiber cast): http://cgi.ebay.com/ebaymotors/Skyline-R33...=item3cad62aa35
The thing is, with the carbon fiber ones - I've been told that the word "GTR" is only ever is embossed on one side being the right side? This is true and why? Does this apply for the Just Jap ones too?
Please advise if I can get a set of "Nismo" ones too?
Cheers,
https://www.sau.com.au/forums/topic/342250-r33-gtr-spoiler-end-caps/
Heres mine. I believe they are stock and came with the car. Its got GTR written on both side.
Yeah that's what I thought....where can I get these from?
Is it the same as those JustJap ones?
The end caps like that are by Nismo
there are 3 types
one with the older "squiggle" design / logo of nismo
Then there are the ones in the above pictures that just have "GT-R"
then there are the much rarer ones which actually say "nismo" with the o being red as in the new design
all are discontinued bar the "GT-R" ones
they were never a stock item, on the standard production r33
I guys, I've tried everywhere...even tried calling Nissan - said I needed to go to a performance place with ties to Nismo directly.
I actually like the Carbon Fiber looking ones but want them the word "GTR" to be on both sides as it looks a bit weird being only on one side.
If you have any suggestions please let me know.
Hi mate,
These are the same as those JustJap ones - which is fine...but the delivered price is $220 - why more expensive?
Can you try and let me know, please?
Please ignore above message - you have to be a registered member to get accurate postal costings. I used EMS worldwide and it's going to cost me $134 delivered - which is awesome as JustJap would have been $200 + $30 delivered! Cheers.
400r Ones (factory) are the least common obviously ;-)
Pic i took
    • If doing that ^, I'd take the idle up valve out and plug the hole in the pump.
    • You can try capping the power steering idle up valve at both ends if it's old. The valve and the intake manifold. That is something that is known to fail in Toyotas with age and it will suck power steering fluid into the intake and burn it in the engine which can cause issues. Then bleed it again with engine off first. Do like 30+ lock to lock turns with the front wheels off the ground.
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
