I have recently purchased a rb25 turbo (op6 rear housing) for my rb20. Ive done turbo swaps before and the oil and water feed lines are always a pain in the ass so this time i wanna do it all with braided lines, My question is where can i get a set of braided lines to suit this turbo on my engine?
Any help would be appreciated
https://www.sau.com.au/forums/topic/342289-help-me/
Search Kinugawa on ebay, hes a reputable seller and has good quality items.
If you go to pirtek or enzed you will need to tell them the sizes etc and it will cost alot.
Kinugawa sells kits on ebay, just make sure you buy the right one. If you have any trouble finding one post back and Ill find it for you on ebay tonight after work.
https://www.sau.com.au/forums/topic/342289-help-me/#findComment-5521893
Thanks guys, ill check ebay now. Are the fittings on 25 turbos the same thread size an pitch as 20 turbos?
An r31nismoid i thought braided lines were alot better than the factory steel ones, better flowing an less restrictive? Yes ill only be take this turbo off once but there a head f&*k when it comes time to bolt them back up. And i didnt wanna run the risk of crimping the lines when removing/ installing the turbo.
https://www.sau.com.au/forums/topic/342289-help-me/#findComment-5521967
like nismoid said your better off keeping the factory lines, just replace the brass washers with new ones and away u go. braided lines would be a complete waste of time on a stock turbo. and its actually very easy changing the turbo over..with the right tools
https://www.sau.com.au/forums/topic/342289-help-me/#findComment-5521986
They are not better flowing or less restrictive. Who said that?
A "X" diameter piece of hose will flow the same whether its braided teflon or steel mate.
What you'll run the risk of, with braided, is potential perish/failure over a few years. There are no pro's to going braided for a daily driver
https://www.sau.com.au/forums/topic/342289-help-me/#findComment-5521990
I also believe its better to use the stock lines, best bet is to not unbolt them from the turbo when you remove it. That way it simply bolts back on. Remember there are only 2 to contend with lol, the other 2 are the return and one that connects to a rubber hose.
If you must remove the lines then only thread them in loosely until you mount the turbo, then start up the threads on the block and tighten it all up! That will give you some extra flexibility to get the line back in place. Dont worry too much if you bend the lines a little, just do not crimp them.
https://www.sau.com.au/forums/topic/342289-help-me/#findComment-5523238
    • Thanks for your insight, it being basically useless will impact my decision for sure. I thought it may help the engine breath better I guess. But then again, I have also been told that tuning an RB20DE is also not worth it. Exactly, we follow EU Regulations. There is a bit more leeway on older vehicles. My Porsche 924 came without a cat from factory and managed to pass, they still mentioned that I have quite high emissions on it though.
    • My apologies, I stand corrected. Thanks for registering to mention this! And thank you for actually reaching out to the council to clarify. This is the sensible thing to do and the opposite of what I was alluding you were doing. I may have seen too much outrage and hate being fueled on the internet and it has made me a somewhat cynical old man. Sometimes it is easy to forget that there are real people behind websites and accounts. In my defence, CarExpert and CarExplore do read quite similarly at a glance. I shall try and do better in the future. (Please stick around to get the latest scoops on dealing with old Nissan shitboxes )
    • Don't bother. The poor little RB20 doesn't make enough gas flow to challenge the flow capabilities of even the littlest cat, and you won't make any extra power, and all you'll do it soot up your rear bumper. Plus....is Malta not runing under Euro regs?
    • Hey Daniel, sorry to hear that and thanks for posting up for us at a really hard time I only knew SmoothLine through the forums, we never met as we are based in different states, but when he was most active on here he was quite a while back so not many of the current crowd might remember him. I am pretty sure he was active in the Queensland SQU club but that is defunct now too (times are changing and we are all getting older). Farewell SmoothLine!
    • Turns out depending on whether the car was equipped with TCS or not there are different signals coming to the dash, meaning there are different speedo clusters.  Wired in a speedo calibrator box from aliexpress and now works fine.
