WRECKING R32 GTS plus a few other parts here and there some will suit s13's
alot of the parts are in good nik but if u have any questions about the condition of any parts ask and ill give you a run down of how the part is
im located in logan area brisbane qld prices do not include postage
any questions call me on 0432 744 627 or a text would be better =). send a text for any pics
genuine Uras front bar $250
genuine Uras rear bar $200
genuine Uras side skirts $150
genuine Uras F/G fenders $150
Gts front bar (needs some attention) $50
Gts rear bar $50
Gts standard fenders $50
Front r/h indicator $50
Mirrors l/h + r/h with loom (no mirrors in them) $100
Front head lights both sides $200
l/h + R/H doors with glass and motor intact $120 ea
boot lid $ 80
bonnet $80
rear qauter glass both sides $80
suroof with intact glass $200
Rb20de motor and gear box working perfect $1500
Radiator $ 50
Fan shroud $30
AFM $50
Radiator Reservoir tank $20
Windscreen washer tank $20
Rear windscreen wiper motor with stripped bolt (crc and some elbow grease will see it like brand new) $30
Engine and gear box mounts $ 30 ea
Standard ecu $60
Power steering rack $80
Height and dampener adjustable greedy coilovers with greddy in cabin dampner control unit perfect order (done maybe 5 -kms if that) control unit never fitted still in box $ 1800
bilstein shocks excellent condition $ 400
4 stud standard wheels 15' inch with fairly bad tires would recommend getting new tires $300
Multistud advanti race project wheels 17x8.0 x2 17x8.5 x2 geat looking, performing wheel (NEVER used) -still in box comes with nuts and center caps $1200
Front and rear Brakes( in perfect order )$ 300
Upper control arms $ 40 ea
Lower control arms $40 ea
Knuckles $ 150 for front
Driveshafts $40 ea
Tail shaft $ 80
Diff centre or hole diff $ 300
Blitz racing brake pads brand new still in box valued at 400 selling $200
Standard rotors plenty of mil on them $150 for all
Both side door trims $50
Rear qauter trims $50
Front seats $ 200
Rear seats $150
Bride gias low max II reclinable seats (universal rails) little scratch from moving but never used $ 1200
Centre console $40
Dash with no vents$ 80
Speedo cluster
Cluster surround (slight crack hardly noticeable) $30
Climate control console $100
Glove box $30
Momo steering wheel $40
Old crappy sterring wheel think its autotchnica $15
Boss kit $ 30
Drift carbon gear knob with extra fittings $15
Sunroof control panel $ 30
Pillar plastics $15 ea
All foot petals (manual) $ 50
Kick panles $30
Gear stick and hand brake boots brand new in box (black leather) $ 30
Jvc flip out 7 inch slave screen $ 60
Sterring wheel surround $30
Seat belts $ 200
Driving flip down sun shade things $20 ea
Gts rear bar $50
boot lid $ 80
bonnet $80
Radiator $ 50
Fan shroud $30
AFM $50
Standard ecu $60
Driveshafts $40 ea
Tail shaft $ 80
Front seats $ 200
Rear seats $150
Centre console $40
Speedo cluster
Glove box $30
Boss kit $ 30
Kick panles $30
Seat belts $ 200
most prices are negotiable
is the box auto or manual? and how many KMs has it done?
its manual and its done 140,000
though its pretty much perfect doesnt slip clutch is fine no problems that i could find when driving
Gts rear bar $50
boot lid $ 80
bonnet $80
Radiator $ 50
Fan shroud $30
AFM $50
Standard ecu $60
Driveshafts $40 ea
Tail shaft $ 80
Front seats $ 200
Rear seats $150
Centre console $40
Speedo cluster
Glove box $30
Boss kit $ 30
Kick panles $30
Seat belts $ 200
Hey, I know this was from ages ago but it popped up in a search!
Still have the bilsteins by any chance???????
Cheers.
sunroof - condition of rubber seal around it?
rear bar - is that the reo or the stock rear bumper cover with everything attached?
  • 4 months later...
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
