G’day all
So excited my first thread… But anyway moving right along
Just a quick question. I'm in the process of fitting my CAI and I’ve found a bizarre censor I’m not sure what it does. I had a quick cruse around the site to see if anyone else has not known what it is but I came up empty handed. It’s a black circler sensor of about 1 inch diameter that appears to be microphone or something. It’s mounted on a small tin bracket with one bolt fixing it to the chassis from inside the wheel arch.
All I want to do is relocate it but I’m a little apprehensive to if its a knock sensor or something. I haven’t got a picture but I reckon I saw some else’s setup and they’d removed the sensor. Is it safe to move? And what is it for?
Better go as its Valentines Day and I’m already being accused by my gf of having a raunchy affair with my car!! They just don’t get it…
Thanks guys
https://www.sau.com.au/forums/topic/34231-name-that-sensor/
Of the before mentioned i like the sounds of the warp drive senor... maybe i could get another!! As for the others its a 93 so no air bags and unless it had an alarm in japan its not that sides its got one of those standard nissan looking plastic clips that joins it to the wiring loom.
Thanks for the thoughts thou guys. Shouldn't matter if i relocate it to the other side of the CAP.
https://www.sau.com.au/forums/topic/34231-name-that-sensor/#findComment-692523
    • Aren't these run off of high voltage in OEM applications? Like 200+V. Or at least 48V in mild hybrids. At ~18,000 BTU ballpark nominal capacity the power draw is at what, 2.2 kW? ~185A is a pretty crazy amount of amps. At 200V it's only 11A. The 70A nominal kits with up to 100A peak draw I see for stuff like classic Porsches have pretty substantial compromises like shutting off at idle and not actually managing to keep the interior cool in hot conditions because they can only output like 6000 BTU. IMO if I had to pick what high amp draw component to retrofit to these cars I would start with the engine fan, not the AC compressor. You need an ~850-1000W brushless fan, something like this: I would love to see the data but I would bet that whatever you save by running the AC compressor in a more efficient regime with an electric motor you're probably losing to conversion losses anyways. It's not really like a clutch fan where you're losing power all the time even when it's nominally disengaged and it gets worse as it engages because the envelope tracking isn't that precise.
    • I am a volunteer marshal at the Grand Prix. As such, I get a "friend / family" ticket. It is a general admission ticket, valid for all 4 days. Anyone interested in my spare pass, please DM me. Ticket is "free, gratis and no expense".
    • agreed, the price vs gains it’s there.   unless you go china supercharger. Temu racing anyone?😂https://www.facebook.com/share/15nkfpsg7Z/?mibextid=wwXIfr that was one of the ones that popped up on my feed 😂
    • Bit of a long shot but if anyone has 4 of these laying around in new or near new condition. I will happily buy them off you.     https://skylinespares.com.au/product/stabilizer-door-glass-inner-new-8032404u03/?srsltid=AfmBOop6L5EgUFaHPHiVXoAhv5k8aJYwc77nGmoApp-hY03OiOsNVaOv Thanks
    • I'm wondering is the Toyota and Mazda "collaboration" could see that new Toyota ???G20 ??? turbo engine that they have been showing off recently into a future MX5, apparently it's good for 400hp out of the box That could easily, possibly, be much better than the last collaboration between Toyota and Subaru with the boxer engine in the twins
