Sadly, yes.
If you have standard turbo in it, it is a damn good idea to upgrade the turbos while you're at it...
Welcome to GTR ownership.
It's all labour mate, remove all induction piping, remove front turbo and manifold, then rear turbo and manifold. Oil lines, water lines, etc. Even then some studs might break, it may cost more.
If seeking more power down the track perhaps think about upgrading the R32 dumps? Replace the gaskets between the manifold and turbo, and turbo + dumps? Cheap stuff to do while you have all the gear taken out mate.
yes it is running stock turbos still so this makes more decsions ;)
what am i looking at for a set of replacement turbos and would it
need a tune/other things costing lots of monies?
i dont want to replace this gasket then have a turbo blow
Only $800?
Thats reasonably cheap, its an absolute cnt of a job ;)
Replacements would be $1200ea (Garrett -9s), then R33 dumps - $150 or so.
Id certainly look to changing turbos mate, added cost, but by god you dont want one letting go :)
Grab a pair of HKS GT-SS that R31Nismoid is selling (maybe PM him but I remembered him mentioning).
And Power FC while you're at it.
What other mods do you already have?
Well, in this case, grab a pair of Garrett 2860 -9s and buy my HKS adjustable actuators then.
This @18 psi + front pipe, decat (or hi flow cat if you're a girl) + cat back zorst + power fc = 300kw.
The car is stock with only coil overs and strut braces.
I'm not looking for any power increase, I like the car as is, just want reliability.
The mechanic that has the car now is doing a price on some reco'd steel turbos.
Are reco'd turbos a bad idea? I have looked at HKS ones but they look pricey.
Reco'd http://cgi.ebay.com.au/R33-GTR-Turbos-N1-S...b0#ht_858wt_783
HKS GT-SS 2860-7 http://cgi.ebay.com.au/Nissan-GTR-R32-R33-...ed#ht_616wt_783
Thanks for the help
yeh that's pretty cheap price.
my rear turbo exhaust to dump gasket went and both turbos and manifolds had to come out.. its a c*nt of a job, i replaced most of the other gaskets and washers that side of the motor and parts alone came to 400-500bux, thats including inconnel studs and nuts.
if u know how to turn a screwdriver just do it yourself.
ill do it for $400 + beer haha
but yeh its a big job, i can do it in around 4 hrs now turbos on and off, but i have done it that many times i have lost count, if you do it yourself expect to be there the whole day and night but all fun :)
just get some steel wheel turbos in there you can get them for around the $1000 mark, all new gaskets so another $60 and a pair of ss dump $300 and ur all good to go.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
    • 100% is gyprock, I agree. Slip of the keyboard. Haha! I left my indicator bulbs out to save a bit of weight.
