Hi again,
I know this is a bit of a amateur-hour question, but can someone give me guidance on where to put the jack-stands when lifting the front of the car, assuming the jack will be lifting from the cross member?
On the S15 I could jack and stand from the sills without any problem, but either the GTR is just plain heavier or the sills are softer - every time I touch them with a jack they sound like they are made of brie cheese.
Cheers,
Andrew
https://www.sau.com.au/forums/topic/342320-jack-stands/
jack under the fake frame rails (nearly even with the front of the door jamb )but behind the split or it will crush in slowly
or you can jack up the car one side at a time and put them under the crossmembers, my car is so stiff I can floor jack up 1 side and 3 wheels come off the ground..lol oddest thing to see ever... but not real safe to be under..lol
Edited by sapphiregraphics
https://www.sau.com.au/forums/topic/342320-jack-stands/#findComment-5522202
my GTR will have 3 wheels off the ground, its because i got Tein SS in there, with the stock suspension the wheels would still touch the ground.
u used to jack the car from the gearbox mount near the drivers side door then go around to the front and do the front from the subframe.
but i managed to now get the jack under the front spoiler and jack from the subframe on one side of the front, this makes it a little easier doing it this way.
i always try and use solid points like the subframe.
i onced used one of those scissor jacks and had to lift is as far as it would go to get a brick under the car to support it, just as it was just about as high as it would go the scisor jack gave way and bent and the car fell back into me and pushed me. lucky i didnt have my knees under the car or anything like that, it just pushed me away.
lesson learnt, dont use scissor jacks!
i'm gonna try and get a mate to make up some wooden ramps to get the car up maybe 90mm so it will give some more room when doing oil changes, or when i need to get under there.
a low profile jack would be awesome!
https://www.sau.com.au/forums/topic/342320-jack-stands/#findComment-5522314
thanks for the help guys.
I jacked it yesterday using the crossmember as the jackpoint and stands under the camber bushes. not sure they are mean to take any load (ie I'm pretty sure they're not!) but unless the jack fails there is minimal load on them anyway.
happy car:
cheers!
https://www.sau.com.au/forums/topic/342320-jack-stands/#findComment-5526030
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
    • You would need to paint your hardtop again though
