He means, "How much negative clearance is there between the back side of the wheel disc (or spokes) and the outer face of the brake caliper?" Brake calipers can foul by being too large a diameter for the inside of the barrel, or they can hit the back of the disc area. People often ignore the latter possibility.
Sorry PranK what does that mean! This is the first time I’m buying aftermarket wheels so I’m learning all the new terminology on the go haha
No. The tune is f**ked. The numbers you put in the computer, aren't right. If you keep driving the car, then it seems you want to take even longer, and spend even more money fixing a broken motor.
No, on the basis that the CAS shouldn't be f**ked with, and if it is, it should be set back to the correct base timing with a timing light immediately.
