Hi All,
I've been searching a few bit through these forums and on google etc etc.. Chasing some genuine ganadors for my R34 GTT Sedan but not having any luck.
rhdjapan and nengun seem to only have them for a 2dr and it specifies this. From what I've read it's something to do with the frame around the mirror is different between a 2dr and 4dr??
Does any one know where to get them for a 4dr or have you heard of them being available?
Any advice or links appreciated (even pics of a 4dr with ganadors or similar is appreciated to see if I wanna continue the effort of searching for some)
ta,
Steve
I've seen 2dr ganadors fitted to a 4dr and they look really stupid and the angle is completely wrong.
Julz - No I haven't I'll have a search around now but I've not had much luck with aftermarket side-view mirrors.. it's by no means vital was just having a look.. might just spend that money on injectors or something useful.
thanks guys and if you do find any aftermarket 4dr mirrors please post brand or links?
ta
    • What ECU is on your car @silviaz? You can just change the idle target table yourself and the IACV duty cycle. Noting that if you play around with the screw you'll also need to revisit the idle base duty table as you will end up offsetting the lot. Another reason why DBW is superior, there's less mucking about.
    • Yep. Saw that on the image above but, wonder if it makes more sense to clean out the iacv because let's say in theory mine is dirty and if I clean it the rpm will drop. If I first go to my tuner to drop the rpm and then go to clean my iacv won't it drop further or is the rpm a fixed number?
    • Yeah it was a good result, and confirming the car is full of fluids and all interior etc in, other than fuel. I think a few pages back (maybe many pages!) he mentioned some serious lightening in the doors with the chassis punch, might have been done elsewhere I hadn't seen yet too
    • He still had the suspension dialled in for him! I would have sworn the lowest weight he ever got to was 1300kg though Maybe Neil had been drilling a LOT of holes somewhere you haven't found yet... 😛 Or has he also drained all the gearbox and diff oil out too, between it, and a tank full of fuel there's about 65kg to 70kg to add back in I'd guess. 😛
    • Yeah this isn't a super complex shape, but I was still happy to buy instead of fab version 1; very little in a modern can is a flat surface, and that is true here again - the undertray has about 50mm in height differences that I would have had to work out myself. I will probably make something more substantial before it does any rally, I don't think 1mm steel is too much use as a bash plate. There is also cooling to think about, Z1 have done a bit of development and have some air holes and louvers in the shape, will see how that works out too
