Hey Guys,
The drivers power window mechanism in my Cefiro went yesterday & I’m having a few problems finding a new one. In the parts list it says that the 4 door R32 mechanism fits but after going to Nizzpro today that apparently isn’t true. The one out of my Ceffy is a cable & slide sort of system (see pic) & apparently the R32 4 door is a scissor style. If anybody has a 4 door R32 can you please have a look & see what style you have got, or maybe any Silvia or 180 owners can do the same.
I’m located just south of the NSW border & I can’t find a Ceffy one, I’ve tried Rollins & Nizzpro but no luck, I also tried to contact RMA Imports but the number listed put me through to some Asian woman that could hardly speak English. If anyone can let me know of anywhere that would be likely to have Ceffy bits, that would be appreciated as they can be quite a pain in the arse to find at times.
https://www.sau.com.au/forums/topic/342414-power-window-help/
like ^^ said , r33 4d look very close to that (also 2 door look very similar , but i've never compared side by side) . next place to look as silly as it sounds , try au/ba look very similar also . if the cable is ok you can pull the motor apart and replace that too , try jay car or places like that for a motor
my drivers reg did the same thing and closest replacement I could find was u13 bluebird, I used the cefiros rail and window bracket, and fitted the bluebird motor and cable to it, the motor is very similar and the cable is a similar length, but I had to do a mod to the cable stoppers (add some length to it) yea, really really difficult to explain, so I won't get into it, but if you do this the mod that needs to be done will be evident
    • Duh... to answer my own silly question, it's actually described in the FSM... ...400 pages away at the end of the manual, for RB25DE/DET signal descriptions, it cites the TPSwitch signal action, is dependent on the TPSensor value ~ this tends to infer the builtin POT voltage signal is the primary, and the switches are fallback/secondary should the POT fail/TPSensor signal lost (and switch alone with no TPSensor signal allows for base idle speed setting).... makes sense... they (TPS units) used to fail/wear the POT with time, they're not exactly built to last ~ having the switch as a redundancy gets around this...(or, it's less likely both signals would be lost as they're on different power rails)... and of course wrt RB26DETT, you have to electrically disconnect the IACV solenoid from the harness, to defeat idle air control...
    • Dose is unaware just how much fun 145-150kw would be in a 2.5L NC MX5. It would be one of the most fun things to drive to ever grace SAU.
    • Same thought crossed my mind ~ depends on how one connotes 'stalling'...ie; gets a rough/stumbling idle as it get warm until it stalls... or... idles ok and simply falls-over when it gets to temp... ...you can test the whole circuit with a couple of resistors ...unplug coolant temp sensor, bridge terminals with a 2K7 resistor (ECU will do cold start), or with engine warm bridge with a 330R resistor (ECU will consider engine to be at normal operating temp)...it's a quick way to check wiring integrity/ECU response when you don't have a multimeter handy ...
    • They also make them with the motor mounted on the side
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
