My Reverse lights in my R33 Gts-t are not working , but when i bought the car bought 8 months ago all was good. Pulled the old bulbs out to see if they were blown , but all was good. Anyway still replaced them with new ones but still no reverse lights ! Is there any fuses or relays which could be the problem , everything else in the wire department looks good & intact. What could be causing this ?
https://www.sau.com.au/forums/topic/342426-reverse-lights-in-r33-not-working/
Found the problem , it's the sensor on the gearbox when you put it in reverse. If you slightly push the gear stick to the left while in reverse the lights go on , but when u let it go the lights go back off again. So the sensor is playing up then ! Now how to fix the problem is the next question !!!!!
ive heard of the switches coming undone half a turn or so causing them not to work unless holding the lever over to the side like you. but thought you had to undo the trans crossmember to get a bit of space to get it out?
