Thanks, good info.
"Some people believe that if they fit a very big intercooler with large ducts, the volume of charge air within it will unduly slow throttle response. Their concern is unjustified however - throttle response problems (for example, turbo lag) are largely the result of other factors within the forced induction system, not the volume of air within it." <- Thats exactly what I needed cleared up.
I had the JJR return flow.
The core was not gold for starters, its just a bad pic. Next the core was significantly better quality than their usual bar and plate 300x600.
When I bought mine I walked in to buy a blitz, on careful inspection I decided to go the JJR. Core looked like it would flow well on the outside and end tank/internal design looked excellent also.
I will buy again if this quality is maintained on other JJR cooler products, it really was a first.
I have blitz and will go blitz again.
Do a search i have seen a few threads on here where ppl have hit 250rwkw with the jjr and couldnt go any higher no matter how much boost they tried to put into it.
Hey personally, i think go the Blitz Return flow cooler, with the cooling pro and HDI, its a hassle to cut the fan and make the hole n stuff... Speically while cutting the fan blades,ull have to cut it so much that it defers the purpose of that fan...
Save the extra buck and get the Blitz Return flow, easy to install and great performance...
if your not planning an rb26 or a front facing plenum deff go the blitz, will keep your engine bay very need, no need to chop the thermo fan and its a good price, i remember when you couldnt get a jap brand cooler kit for under 1k.
if your going front facing plenum later grab the hdi kit
Just to confirm, Cooling Pro return flow kit requires trimming the thermo fan blades but the Blitz CS/SE does not?
Does either kit have the nipple for the R34 power steering line or do you have to drill & add it yourself for both?
And what about the washer bottle, does it need to be moved or replaced with either kit?
Sorry to hijack the thread, just trying to make up my mind between the two...
Trimming the thermo fan blades? What drugs are you on? Does not go any where near there thermo fan
Lol dude, both Zaver and s13_Skyline_inside mentioned something about chopping the fan (see quotes in my previous post above), just trying to confirm if that's really needed.
Think that's in reference to the non return flow coolers not the return flow JJ cooler
I stand corrected, first time i have heard of it tho, when i first got my 33 it had an over the radiator set up and the piping was closer to the engine than the fan.
And to answer you questions.
Return flow kits hook up to the factory piping, i believe all will need a little or a lot os trimming of the front bar but not the fan.
Pass
In my 33 the non return flow that was in it had a hole down from the washer bottle, didnt have to be moved, i would assume that the 34 would have much the same lay out.
  • 1 month later...
what about HPI not HDI - sold by Just Jap for $499 from $799??
link:
http://www.justjap.com/store/product.php?productid=16892&cat=339&page=2
This is a supposedly JAP brand but not much info about this on the net - so now I'm left with the HPI kit, HDI and the Cooling Pro Stealth to choose.
Has anyone used these HPI kits and what are their views??? Please help me to decide between these three- the Blitz is to expensive.
cheers
thanks mate, thats impressive, didnt think the jjr stealth cooler could withstand 300KW+, what turbo r u running and what other mods?? Do you know your torque figure and what does it feel like on the street - ie low-mid range punch...:thumbsup:
cheers
307kw with a jjr return flow no sign of any restrictions or problems they are one of the few that are cheaper but still perform well.
cheers
Check the rb25 dyno results thread mines one of the last ones there with the dyno sheet. I have cams fitted so yes I got the low mid range punch power band is unreal im running e85 though.
    • The new project has arrived. I have wanted one of these for such a long time, well before that meathead Clarkson drove one in Africa. I really wanted an E34 but I have some medical issues that mean I *really* can't bump my head and the lack of airbags in the E34 made it just too big of a risk.  I don't know why I've always liked these older touring BMW's to be honest, but man I love this car. She's been pretty well maintained for her 243k's with what appears to be only a single oil leak at the oil filter housing gasket. It has a bunch of updates including later model bumper and headlights, 7 series billion-way adjustable seats and it came with a few spares and another set of wheels with legal tyres. I got a unregistered car permit from the RTA and drove it back from Canberra on Saturday.                   First cab off the rank is cleaning it up for blue slip. I dont know how picky they'll be but I figured I'd clean the headlights, fix the oil filter housing gasket, replace the speed sensors (throwing errors) and swap the OE wheels (the M Sport wheels have a big chunk out of one of the tyres.) I also need to replace all 6 gas struts - 2 for bonnet, 2 for hatch and 2 for hatch glass. The car tries to eat me whenever i open any of these. My plan for this car; Ultimately, this is a budget car. I can't afford to throw lots at it and its because I have another car that I got this, if something breaks its no big deal. I will just maintain and repair it really. But eventually I want to do a manual conversion. It actually looks pretty straight forward for E39's and the trickiest part will be sourcing the parts.  I do need to replace some suspension arms or bushes because wow, she's a floaty old girl. She's also fantastically slow. Like really, really slow. When pulling back out on to the freeway on Sat after a quick pull over I needed to wait until no cars were visible before going.  Oh, and the guy I bought it from had a gorgeous R31 GTS-X in the garage.
    • Do you have a picture? I assume it is a breather for gearbox oil as it expands, it should have a vacuum line run nice and high in the engine bay (R32 GTR has it on a top bellhousing bolt)
    • Hi all, I am putting an r33 gtst gearbox into a VL and have noticed what looks like a vacuum barb on the box (on top in the middle). Suspecting that it's a vacuum line but I'd like to double check, if someone could confirm the function of that would be great. Cheers in advance.
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
