So I just got my car back from the tuners and Im not really disappointed with the results but am wondering if the dyno printout shows any issues.
253.2rwkw
HKS2835 ProS
sard 550cc
front facing plenum
powerFC with boost control kit
splitfire coilpacks
arc air intake
stock cams
adjustable exhaust cam pulley
98ULP
its disappointing that the dyno print doesnt show rpm so I find it harder to read than normal, but more experienced people may be able to see something from looking at this printout...
Does boost control look right?
Do I need the rpm indicator for more info of how the setup is performing?
Is power output lower than expected?
Any suggestions?
I did expect more peak power tbh, but Im more interested in midrange.
https://www.sau.com.au/forums/topic/342457-hks2835-tune/
  • Replies 182
Its got boost control issues. You won't be able to make more power till you can hold it straight at around 18psi. needs a stronger actuator and hopefully it rules it out. I would go for a 24psi atmospheric pressure rated actuator, whichs should hold 18psi without boost controller. Garrett part: 446131-23
https://www.sau.com.au/forums/topic/342457-hks2835-tune/#findComment-5524495
Agreed.
Compare the green line and the pink line. The green line is more flat in boost and therefore the power curve is more straight. The pink lines boost curve is a bit wavy and drops in higher rpm and is reflected by the pink power line.
Even so, the boost is very lazy coming on in the red and green line, not as bad on the pink, but still could be better.
What was changed between the red and pink runs, other than the peak boost? Because boost comes on a lot differently between the two.
Fix the boost issue to come on a lot harder and you will have better bottom end power, and fix the boost issue to hold boost better to redline and you will get your peak power.
Edited by PM-R33
https://www.sau.com.au/forums/topic/342457-hks2835-tune/#findComment-5524498
Boost control is poor. Evident @ 135km/h where it drops off and so does power
The Dip around 120km/h is not related to boost however, tune would be most likely.
Fix the above two issues and you'll gain a soild 30-40rwhp in the midrange once you give those dips in the graph the flick.
It will be very noticeable once you do as well.
Also with boost holding into upper RPM likely peak power should increase also another 30-40rwhp as a 3-4psi drop is certainly hurting.
https://www.sau.com.au/forums/topic/342457-hks2835-tune/#findComment-5524696
i also agree
its not holding boost to red line it start dropping of power fairly early/midrange
if it held boost correclty that turbo should see around the 280kw mark with those mod,
also how big is your exhaust, dump pipe, front pipe mainly
i had issues with that same turbo, ended up upgrading the front pipe to 3 1/2 " and fixed the issue i had with power output
https://www.sau.com.au/forums/topic/342457-hks2835-tune/#findComment-5524715
thanks for the advice guys, I did think the boost control seemed a bit shaky...
I'm running the std HKS actuator and the PowerFC boost control kit...
I do have to go back for a bit of touch up on the tune so I'll see what they think but they felt the turbo was 'running out of puff' at 17psi so suggested the 12psi tune was the best compromise between power and not pushing the turbo too hard... I honestly expected 18psi as a start and go slightly up from there...
https://www.sau.com.au/forums/topic/342457-hks2835-tune/#findComment-5524892
needs more gain/duty
its not running out of puff at all, if those boost lines were all flat all 3 runs would be making peak power right where they backed off which is ~ 6800. hardly running out of puff. get it running a nice flat line at 18psi all the way to limiter and you'll notice a huge difference.
the pink line doesnt reach full boost until ~4600 and gets there very lazily. should ramp up hard and hit 16-18psi at around 3600-3800 at a guess
https://www.sau.com.au/forums/topic/342457-hks2835-tune/#findComment-5525059
Yeah I was thinking that but they seemed really nice and helpful and they have a heap of experience...
I gave them the task of installing the bov and letting them choose which one they wanted to use, the stock one or a atmo HKS, they chose the atmo bov but they did ask where I wanted it installed I said well as close to the thottle body as possible, so under the drivers guard is the only space really.. when I picked it up they said that they were really impressed with how everything was installed and that the bov positioning worked really well, 'Im going to set them up like that in the future as well...
bit of a worry, but the idle is fairly good and none of the normal atmo bov issues...
https://www.sau.com.au/forums/topic/342457-hks2835-tune/#findComment-5525074
so new actuator to replace the HKS supplied one or does the pfc boost control just need some tweaking?
https://www.sau.com.au/forums/topic/342457-hks2835-tune/#findComment-5525090
and of course that will mean adjusting the fuel map as well right?
and that will I suppose cost me more right?
and here I thought getting a tune from a reputable workshop would mean first time done right...
https://www.sau.com.au/forums/topic/342457-hks2835-tune/#findComment-5525105
yes the tune will need tweaking. there seams to be a lot of workshops out there that dont bother setting up boost control and light load maps properly, even reputable ones.
personally i'd take it back and have a talk to the tuner and ask him why its set up to come on boost so lazily, see what he says
https://www.sau.com.au/forums/topic/342457-hks2835-tune/#findComment-5525113
well I did what I thought was right but I would of thought the tuner would atleast think it checking it surely??
I did tell them I did all the installs myself and did my best but they should atleast check what I have done...
atleast Im hearing what I was concerned about that it could be better and that unfortunately it still needs some work at the tuners...
https://www.sau.com.au/forums/topic/342457-hks2835-tune/#findComment-5525144
Yeah i guess it just depends on the circumstances, tuner, time etc. But setting up the actuator is something you can do yourself and then just have the AFR's checked on the dyno. What duty cycle is the Boost control kit set to at the moment?
Edited by White GTS-T
https://www.sau.com.au/forums/topic/342457-hks2835-tune/#findComment-5525225
    • Breather for it. If it's anything like the GTRs it should run up to the top of a bellhousing bolt.
    • What basics? With these OBD1 ECUs it's not like the ECU will give you any real clues, it's not really doing any sanity checking of sensors/sensor data. My experience is actually a lot of sensors tend to be the source of the issue first and foremost, and checking everything gives you a direction to investigate. MAF/O2/STFT/LTFT should all kind of make sense. You can try little tricks of the trade like tapping the MAFs to see if it triggers a stumble, things like that. But once you've done a compression test knowing whether you have an air leak or fuel delivery problem is kind of hard to narrow down without sensor data. And you don't really know if all your sensors are making sense unless you can interrogate the ECU directly about what it's seeing for sensor data.
    • Absolutely this. Yes, except not vacuum hose. Something oil/fuel safe is a better idea.
    • Like a Stagea, but not as cool! Hope you have enough garage space for this, or is something going to leave to make way for it?
    • The new project has arrived. I have wanted one of these for such a long time, well before that meathead Clarkson drove one in Africa. I really wanted an E34 but I have some medical issues that mean I *really* can't bump my head and the lack of airbags in the E34 made it just too big of a risk.  I don't know why I've always liked these older touring BMW's to be honest, but man I love this car. She's been pretty well maintained for her 243k's with what appears to be only a single oil leak at the oil filter housing gasket. It has a bunch of updates including later model bumper and headlights, 7 series billion-way adjustable seats and it came with a few spares and another set of wheels with legal tyres. I got a unregistered car permit from the RTA and drove it back from Canberra on Saturday.                   First cab off the rank is cleaning it up for blue slip. I dont know how picky they'll be but I figured I'd clean the headlights, fix the oil filter housing gasket, replace the speed sensors (throwing errors) and swap the OE wheels (the M Sport wheels have a big chunk out of one of the tyres.) I also need to replace all 6 gas struts - 2 for bonnet, 2 for hatch and 2 for hatch glass. The car tries to eat me whenever i open any of these. My plan for this car; Ultimately, this is a budget car. I can't afford to throw lots at it and its because I have another car that I got this, if something breaks its no big deal. I will just maintain and repair it really. But eventually I want to do a manual conversion. It actually looks pretty straight forward for E39's and the trickiest part will be sourcing the parts.  I do need to replace some suspension arms or bushes because wow, she's a floaty old girl. She's also fantastically slow. Like really, really slow. When pulling back out on to the freeway on Sat after a quick pull over I needed to wait until no cars were visible before going.  Oh, and the guy I bought it from had a gorgeous R31 GTS-X in the garage.
