  • Replies 182
I can imagine it would be hard to be a tuner just like its hard to do any job but if I did something in my job that my client wasnt happy with they would ask why too wouldnt they...
oh slap, hey I should of just added a smiley face it was a bit pun from other threads I read, I have no experience with hypergear and I think he does a great job...
and I do appreciate your help, its more confirmation for me tbh Im obviously able to see there is a problem, I wouldnt say 'clearly need' though.
so do you have anything constructive to add or are you just venting?
The way it is written looks very different. I think you should change it as the way it is written is basically defamation of a company.
As others have said crank up the wastegate preload. It should only be roughly $100/hour of dyno time. It should be less than 2 hours.
Also pickup one of those $30 turbotech boost valves. It solved the GT3076 problem the other day.
I would be very tempted to have a cheapy turbotech boost controller handy just in case the PFC boost controller is either playing up or has been setup poorly.
$30 is cheap to rule out a potential problem.
Wastegate pre-load is still the most likely issue that needs to be checked.
I just swapped a GT-RS for a 2835ProS on the Stagea and it made 262rwkw at 16psi (bleeding to 15psi) and it was all in pretty much around 3300rpm (from memory). I know there is more average power to be had with fine tuning light, light/medium load but the headline number is pretty consistent with other results.
You will sort it out.
  • 4 weeks later...
Finally got the car back in for another tune with adjustment made to the wastegate... now making 290rwkw, I'll post the dyno sheet once I pick them up...
this time the dyno print should have rpm, boost & afr for a better overview...
Thats fantastic news mate! Well done. Awesome peak power figure and knowing the turbo it will have a very strong mid range.
Just concretes my opinion that these are the best turbo for a stockish RB25 engine.
Well all the reading and research lead me to believe this was the best choice turbo for response vs power, the tuner believes the turbo is too small, but maybe he thinks Im chasing power beyond the 2835s range, I would of been happy with 275-285rwkw tbh, which I thought the turbo was well able to do, much less and it would be in gtrs rhelms really wouldnt it...
I cant wait to post dyno sheets and see what people think... Im eager to see afr's myself
the .82 rear is optioned for the 1JZ as well.
I've just got my HKS GT2835 KAI kit, so I'm interested to see the difference in this over the Pro S. Supposed to be the new version of the Pro S but I cant find much info on it, other then it makes a couple of KW more at the cost of some torque? But its still a bit sketchy anyway lol.
Glad to see you got yours sorted mate. Will be helpful if something similar happens to me when my tune is started
Guys the 2835 Pro S kit for the RB25 definitely comes with the 0.68 exhaust housing by default:
http://cgi.ebay.com.au/HKS-Turbo-Kit-GT283...=item20b4f48ef8
The 0.68 is how they get the awesome response and mid range, but it still seems to be big enough to flow 280-290rwkw on 98, which is enough for most people on stock rb25s.
If someone can repair turbos this could be a great buy:
http://cgi.ebay.com.au/R33-R34-RB20-RB25-G...=item19c1223b3b
Indeed it is a good turbo mate, HKS back cut the wheel so flow characteristics are anyones guess.. HKS know what they are doing tho, that turbo is GUN.
Numbers are one thing, but seeing on road results from a 2835 is totally another league.
i musta got the optioned one as i have an 0.82 rear on my Pro S kit sitting on my rb22
awesome... def waiting to see the graph.. +1 great turbo's and good results
Thats strange I thought the Pro S had either a 0.68 or 0.87 exhaust housing??
    • Breather for it. If it's anything like the GTRs it should run up to the top of a bellhousing bolt.
    • What basics? With these OBD1 ECUs it's not like the ECU will give you any real clues, it's not really doing any sanity checking of sensors/sensor data. My experience is actually a lot of sensors tend to be the source of the issue first and foremost, and checking everything gives you a direction to investigate. MAF/O2/STFT/LTFT should all kind of make sense. You can try little tricks of the trade like tapping the MAFs to see if it triggers a stumble, things like that. But once you've done a compression test knowing whether you have an air leak or fuel delivery problem is kind of hard to narrow down without sensor data. And you don't really know if all your sensors are making sense unless you can interrogate the ECU directly about what it's seeing for sensor data.
    • Absolutely this. Yes, except not vacuum hose. Something oil/fuel safe is a better idea.
    • Like a Stagea, but not as cool! Hope you have enough garage space for this, or is something going to leave to make way for it?
    • The new project has arrived. I have wanted one of these for such a long time, well before that meathead Clarkson drove one in Africa. I really wanted an E34 but I have some medical issues that mean I *really* can't bump my head and the lack of airbags in the E34 made it just too big of a risk.  I don't know why I've always liked these older touring BMW's to be honest, but man I love this car. She's been pretty well maintained for her 243k's with what appears to be only a single oil leak at the oil filter housing gasket. It has a bunch of updates including later model bumper and headlights, 7 series billion-way adjustable seats and it came with a few spares and another set of wheels with legal tyres. I got a unregistered car permit from the RTA and drove it back from Canberra on Saturday.                   First cab off the rank is cleaning it up for blue slip. I dont know how picky they'll be but I figured I'd clean the headlights, fix the oil filter housing gasket, replace the speed sensors (throwing errors) and swap the OE wheels (the M Sport wheels have a big chunk out of one of the tyres.) I also need to replace all 6 gas struts - 2 for bonnet, 2 for hatch and 2 for hatch glass. The car tries to eat me whenever i open any of these. My plan for this car; Ultimately, this is a budget car. I can't afford to throw lots at it and its because I have another car that I got this, if something breaks its no big deal. I will just maintain and repair it really. But eventually I want to do a manual conversion. It actually looks pretty straight forward for E39's and the trickiest part will be sourcing the parts.  I do need to replace some suspension arms or bushes because wow, she's a floaty old girl. She's also fantastically slow. Like really, really slow. When pulling back out on to the freeway on Sat after a quick pull over I needed to wait until no cars were visible before going.  Oh, and the guy I bought it from had a gorgeous R31 GTS-X in the garage.
