Well, after searching for a bit and not finding what i'm looking for i'm here
I foolishly added the nulon gearbox additive through the shifter and only read recently that if you do that it goes to the transfer case
So i need to flush that out asap!
Adding the fluid to the transfer case pushed up the level in the reservoir in the boot - normal?
Can u use Dextron 3 in the transfer case? or Does it have to be transmax z or matic-d/j?
tags for future ref: attessa atessa atesa awd 4wd transfer case fluid
https://www.sau.com.au/forums/topic/342472-attessa-fluids/
I have always used "any old auto trans fluid". No name in the stagea, transmax z in the race car.
The resoviour in the boot and the xfer case are not linked....so hopefully what you noticed is a co-incidence.
And yes, you should flush everything out of the xfer case!
https://www.sau.com.au/forums/topic/342472-attessa-fluids/#findComment-5524431
will do
i'll see if my mate at autobarnzzz can do me some discount on some nulon syn stuff and might do the p/s at the same time
is there a walk through with pics for the transfer flush? if not, i shall take some
https://www.sau.com.au/forums/topic/342472-attessa-fluids/#findComment-5524562
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
