  • Replies 55
Trial fitting my Sinco Customs manifold on to the RB30
Hmm, whats the plan for your oil return? Seems like it would be a bit tough running it past the manifold without it touching or getting superheated.
Seems to be more room in Stagea engine bay than Skyline. Will make sure its OK!
I'm noticing that people seem to be spending a lot of time making there engines look pretty. Call me lazy I just wanted the bastard thing running sooner, my car is more like the ugly porn star. It does the job damn well but just a little ghetto at the same time.
Plumbing is arse about face to give enough space for a back seat.
Aiming for 800hp in 15ft - should be fun!
Having trouble uploading more pics 'You did not select a file to upload'???
Edited by roba
Here is my 26/30 going into my black r32
It doesnt look much yet as Im still porting the head.
using
groupA turbos.
550 injectors
2x rb25 afm
extended sump
Ported stock oil pump
lightweight steel flywheel
Just a mild one I will pull the pin at 17psi and 7000 rpm
Just a pic from the top at the moment I just got the covers back
  • 1 month later...
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
