hey guys i have just got another r33 series 1 wreck have alot parts from this and previous ones
spo i have pretty much every part, call or msg me on 0422 868 703 and ask me what part you need
and i should have it. Also will be selling the shell that has been hit at the rear suitable for
track or drifting make an offer, negotiabel on all my prices just ask
parts for sale
* R33 shell??? make and offer
* 5 speed turbo gearbox, excellent condition $1400
* Complete rb25det motor complete with loom $1600
* Professionally rebuilt lsd diff $350 very tight
* 2 factory diffs
* manual turbo ecu
* Front and rear hubs $500
* Rear hubs and brake calipers and discs $350
* Another set of complete front and rear hubs, brakes, calipers etc $800
* Complete turbo conversion $900
* rb5 bottom end $600
* Complete interior parts ( ask me what you need i have alot of series one interior)
* 2x rear bumpers s1 $80 each
* rear boot with spoiler s1 $100
* 400 r style front bumper $100
* 2 Tailshafts $80
* Heater Boxs $80
* Gtr Steering wheel and column $150
* Dash Clusters $80
* 2x passenger side electric window regulators
* Electric mirrors left and right
* Lots of Boot Carpet
* Perfect series 1 bumper
* Series 1 headlights
* Complete perfect left and right doors
* left and right guards (quater panels)
* Apexi 3.5" cat back exhuast
* Apexi air filter
* HKS Turbo Timer
* Stock r33 wheels set of 4
* All windows/glass
* S1 standard grill
* Standard factory floor mats
pretty much i have heaps of parts just call or msg me on 0422 868 703 even if i havent list what
you need i might still have what your after, negiotable on my prices just looking out for everyone.
thanks
i have a lot parts and will sell cheap. please contact me on 0422 868 703 thanks
https://www.sau.com.au/forums/topic/342523-heaps-of-r33-parts-cheap/
    • If you have a RB25DET NEO AWD motor, you will need this: https://www.hioctanedirect.com/ASR-RB26-RWD-Street-Comp-6.5L-Sump-Suit-R32/33/34-and-VL It is made for the AWD motor, but makes it fit a RWD setup and gives you a new pickup. Just one thing, the pickup sits quite forward, compared to a conventional RB25DET RWD motor. This may or may not have contributed to my previous AWD -> RWD shitting the bed at the track.
    • My car is also flex tuned. It's worth mentioning it (the LS1 ECU) has a 1D table for E85 addition and just uses the ethanol stoich part as the second point of reference. It also as a 3D timing map for Ethanol adjustment. You would think this isn't enough but it works pretty damn well. That said, I wouldn't want it in turbo application. It's like lifting non-natty, or taking meth. It gets you unrealistic results that break down more things going forward. If people used it to make the same amount of power they do on 98 then it'd be one thing. But people use it, crank it up to eleventy million PSI, it doesn't knock - but it pushes the point of failure to another, more expensive thing to break. Every time I see someone make 280kw on 98 and 350kw on E85 on the same equipment I just cry a bit and really wish they would just stay on 98 in that exact scenario. It's bad for you.
    • This is kind of what I was thinking but the temp sender wire and the two pressure switch wires run through the starter subharnes and I eliminated the two pressure switch wires completely.  @GTSBoy I have a can gauge with unusually bright warnings should the oil pressure fall so the factory light isn't needed. I need to dig out my wiring diagram and see if I can sort this out.
    • It's a valid point. And it is doable with the Nistune. But I'm not inclined to flex it the way Nistune does - certainly not on a Neo ECU. They're already pernickety enough to tune just one one fuel. And of course, I'm not that interested in putting in a Link or similar, on a daily. With the stock ECU, stock looking turbo, etc etc, I still stand a chance of surviving a run-in with the plod. Last time it went over the pits (which was for the transplant, for because of a run-in with the plod), the Nistuned ECU did not even raise an eyebrow. They want to see a stock ECU running the engine, and they are happy to see it do so without the check engine light** on. Never mind that the Nistune is necessary to make the stock ECU work in a different chassis without ABS, TCS, etc. **And they actually provoke the CEL to come on by disconnecting the AFM, to prove that the globe hasn't been pulled!
    • This is why you flex fuel it...
