hi guys its not a skyline but it is will be rb powered. Roughly 6 years ago i bought my self a 1973 240z
I bought it with plans to do a full restoration and rebuild for a tough streeter with the occasional track day.
I origonaly planed and had the gear to build it with an l28et which isnt a bad thing because they can be very power productive with the right set up.
but i recently found a compleat rb20det and every thing i need except the fuel pump set up to get it running in my s30 hence the reason i am here on this forum
Here are are some pics with with where i am at with the build
this is how it was when i bought it
i had the dash redone by rear spares
i bought some willwoods
cleaned up the suspension
I did a lot of body work and rust repair including replacing the roof skin to get rid of an unwanted sunroof
fit up some fender flares
off the rotisserie and a panel fitments before doing finishing off the body work
and finally my rb20 waiting to be fitted up
https://www.sau.com.au/forums/topic/342533-rb-240z/
im a little bit far away from you. I am in south australia You should get your self another zed to play with.I sold mine to buy an r32. I missed it so much i sold the r32 to buy another zed. I would not swap it for any thing. Just today i had some one wanting to swap it for a late 90s, bmw. I told him hes dreaming :)
https://www.sau.com.au/forums/topic/342533-rb-240z/#findComment-5530953
  • 5 months later...
thought i should do a quick update and show you where i am at
here she is getting some sun on my front lawn
thought i should fit up the intercooler before i paint it
there was not much to it the pipes lined up with the factory vent holes..
I just had to make them a fraction bigger
I now have it at the crash shop were i work awaiting primer so its not far
from paint..
It is a shame that these rims dont fit as they are 5 stud and came off my bosses GTR
If any one wants them they are for sale
https://www.sau.com.au/forums/topic/342533-rb-240z/#findComment-5775124
  • 3 months later...
  • 1 month later...
Hi guys.. Its been a while since i posted so this is were i am at.
I got some rims they are rota rbx in 17x 9.5 for the rear and 17x9 for the front.
I managed to get some time in the spray both to spray some high fill primer on all the panels. now i just need to block it back and wet rub it
and it ready for color
https://www.sau.com.au/forums/topic/342533-rb-240z/#findComment-6036144
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
    • I was surprised to see all the quick Jack models at the same prices on there. But yeah, grabbing one at 20% off would be great.
    • I wonder if these would be discounted when they have their big sales? because if so would be a great time to actually buy them could even end up cheaper than buying from quickjack in the end.
    • Which grit sand paper did you use on the pulley btw? Thought I'd ask so I don't scratch it up too much
