Nothing a tune can't fix, my R33 did the same thing with an rb20 ecu fitted, there is quite a lot of timing pulled in the stock map when the temp is really cold.
No worries. I will just warm it right up before I drive it until I can get an aftermarket ecu. I want to upgrade the turbo and injectors at the same time to bump it up to just over 200rwkw.
Any way here's a few more pics
DC8728E2-8B3A-4AD1-AF16-55E2CAC9FC0C-103
Edited by skidmark
  • 3 weeks later...
How's the rear end holding up under that power? I wanna start a project 240z but I'm afraid that the rear diff won't be able to handle the power. Yours is upgraded or stock?
The stock rear end of a 240z will handle more power than an rb20det can produce. This chassis comes with either a r180. Or a r200 long nose diff very similar to the r32/33/34 skyline. I ran the stick diff for a while but it was only a open 1 wheeler. I now run a dr30 skyline r200lsd which is a direct bolt in.
As far as people saying the rb20det is to small, dont forget this car only ways 1000kgI am still on stock turbo ecu and injectors and this thing has far mor power than I could ever use on public roads. I just love the way it revs so smooth and it sounds awesome.
I will be upgrading to nistune, bigger turbo and injectors in the future but when I do it will see more time on the track than the road
I have enterd a hill climb event I. September so I will add some in cab YouTube fottage from my run's.
  • 2 months later...
I took my car to collingrove hill climbs a few weeks ago
I think I have a new passion. My first run was around 44 seconds.
I managed to get down to a 41 second pass on cheep Chinese street tires
Her is a video of my last run. It was only a 43 second pass because I fell of the track Half way up.
Check it out.
I agree the car looks great, very neat engine install. Lots of 240/280Z here in the states, but I don't see many that are as nice as this one.
I bought a wrecked 240z in 1982, been rolled over and the roof was smashed, so I built a convertible - my first custom car. It was mechanically stock- wish I had the RB20 back in those days. I really like my RB20DET in my RX-7 and I agree the 20 has plenty of power for street driving.
  • 2 months later...
I have decided that I am going to replace the rb20 with a rb25.
I came across the first issue with the conversion.
My custom engine mounts from the rb20 won't work because they fowl on a pipe which
I not sure what is because my rb20 never had it.
What is this pipe and is it important. It goes from the head and in to the block
that pipe is an external oil drain from the head, due to the additional oil from the VCT system on the 25. you'll need to find a way to keep that, or T it into the oil drain from the turbo
  • 9 months later...
So it's been a while.
I have the rb25det up and running in my 240z. I have already had it out for a track day
I seriously didn't think there was going to be so much of a difference over the rb20
But the extra torque makes this thing a complete animal.
There is still a lot of room for improvement but it's getting to where I want it
Before I do any more power upgrades I will be adding coil overs and adjustable control arms.
Any way here are some up to date pics.
  • Like 1
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
    • @99RS4just wondering if you ever took photos of the footwell lighting / how you bypassed the controller, im keen to haver footwell lighting come on when I open the doors too
