  • 3 weeks later...
How's the rear end holding up under that power? I wanna start a project 240z but I'm afraid that the rear diff won't be able to handle the power. Yours is upgraded or stock?
The stock rear end of a 240z will handle more power than an rb20det can produce. This chassis comes with either a r180. Or a r200 long nose diff very similar to the r32/33/34 skyline. I ran the stick diff for a while but it was only a open 1 wheeler. I now run a dr30 skyline r200lsd which is a direct bolt in.
As far as people saying the rb20det is to small, dont forget this car only ways 1000kgI am still on stock turbo ecu and injectors and this thing has far mor power than I could ever use on public roads. I just love the way it revs so smooth and it sounds awesome.
I will be upgrading to nistune, bigger turbo and injectors in the future but when I do it will see more time on the track than the road
I have enterd a hill climb event I. September so I will add some in cab YouTube fottage from my run's.
https://www.sau.com.au/forums/topic/342533-rb-240z/page/4/#findComment-6945383
  • 2 months later...
I took my car to collingrove hill climbs a few weeks ago
I think I have a new passion. My first run was around 44 seconds.
I managed to get down to a 41 second pass on cheep Chinese street tires
Her is a video of my last run. It was only a 43 second pass because I fell of the track Half way up.
Check it out.
https://www.sau.com.au/forums/topic/342533-rb-240z/page/4/#findComment-7066347
I agree the car looks great, very neat engine install. Lots of 240/280Z here in the states, but I don't see many that are as nice as this one.
I bought a wrecked 240z in 1982, been rolled over and the roof was smashed, so I built a convertible - my first custom car. It was mechanically stock- wish I had the RB20 back in those days. I really like my RB20DET in my RX-7 and I agree the 20 has plenty of power for street driving.
https://www.sau.com.au/forums/topic/342533-rb-240z/page/4/#findComment-7067876
  • 2 months later...
I have decided that I am going to replace the rb20 with a rb25.
I came across the first issue with the conversion.
My custom engine mounts from the rb20 won't work because they fowl on a pipe which
I not sure what is because my rb20 never had it.
What is this pipe and is it important. It goes from the head and in to the block
https://www.sau.com.au/forums/topic/342533-rb-240z/page/4/#findComment-7155903
  • 9 months later...
So it's been a while.
I have the rb25det up and running in my 240z. I have already had it out for a track day
I seriously didn't think there was going to be so much of a difference over the rb20
But the extra torque makes this thing a complete animal.
There is still a lot of room for improvement but it's getting to where I want it
Before I do any more power upgrades I will be adding coil overs and adjustable control arms.
Any way here are some up to date pics.
  • Like 1
https://www.sau.com.au/forums/topic/342533-rb-240z/page/4/#findComment-7410787
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
