  • 3 weeks later...
How's the rear end holding up under that power? I wanna start a project 240z but I'm afraid that the rear diff won't be able to handle the power. Yours is upgraded or stock?
The stock rear end of a 240z will handle more power than an rb20det can produce. This chassis comes with either a r180. Or a r200 long nose diff very similar to the r32/33/34 skyline. I ran the stick diff for a while but it was only a open 1 wheeler. I now run a dr30 skyline r200lsd which is a direct bolt in.
As far as people saying the rb20det is to small, dont forget this car only ways 1000kgI am still on stock turbo ecu and injectors and this thing has far mor power than I could ever use on public roads. I just love the way it revs so smooth and it sounds awesome.
I will be upgrading to nistune, bigger turbo and injectors in the future but when I do it will see more time on the track than the road
I have enterd a hill climb event I. September so I will add some in cab YouTube fottage from my run's.
https://www.sau.com.au/forums/topic/342533-rb-240z/page/4/#findComment-6945383
  • 2 months later...
I took my car to collingrove hill climbs a few weeks ago
I think I have a new passion. My first run was around 44 seconds.
I managed to get down to a 41 second pass on cheep Chinese street tires
Her is a video of my last run. It was only a 43 second pass because I fell of the track Half way up.
Check it out.
https://www.sau.com.au/forums/topic/342533-rb-240z/page/4/#findComment-7066347
I agree the car looks great, very neat engine install. Lots of 240/280Z here in the states, but I don't see many that are as nice as this one.
I bought a wrecked 240z in 1982, been rolled over and the roof was smashed, so I built a convertible - my first custom car. It was mechanically stock- wish I had the RB20 back in those days. I really like my RB20DET in my RX-7 and I agree the 20 has plenty of power for street driving.
https://www.sau.com.au/forums/topic/342533-rb-240z/page/4/#findComment-7067876
  • 2 months later...
I have decided that I am going to replace the rb20 with a rb25.
I came across the first issue with the conversion.
My custom engine mounts from the rb20 won't work because they fowl on a pipe which
I not sure what is because my rb20 never had it.
What is this pipe and is it important. It goes from the head and in to the block
https://www.sau.com.au/forums/topic/342533-rb-240z/page/4/#findComment-7155903
  • 9 months later...
So it's been a while.
I have the rb25det up and running in my 240z. I have already had it out for a track day
I seriously didn't think there was going to be so much of a difference over the rb20
But the extra torque makes this thing a complete animal.
There is still a lot of room for improvement but it's getting to where I want it
Before I do any more power upgrades I will be adding coil overs and adjustable control arms.
Any way here are some up to date pics.
  • Like 1
https://www.sau.com.au/forums/topic/342533-rb-240z/page/4/#findComment-7410787
    • We have some genuine Japanese legally decommissioned car number plates now in stock 🙂 Add some legitimately obtained JDM style to your Skyline or other Japanese model, or simply as a garage/man cave decoration! About the 40mm hole: The Ministry of Land, Infrastructure & Transport in Japan recognised the popularity of keeping decommissioned plates among car enthusiasts and came up with a method to "destroy" (or render them unusable for street use) while still retaining their collectable/usable value for display etc.  We have 40mm hole covers available to cover the hole nicely with a Sakura motif, which are also available in white in (very!) limited quantities, however they frequently sell out. Please let me know if you're wanting one or more of these and I'll check availability. The Sakura motif covers are more common. https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set-su-7515 https://www.oemsoko.co.jp/products/genuine-decommissioned-japanese-vehicle-number-plate-set https://www.oemsoko.co.jp/products/genuine-japanese-vehicle-number-plate-400mm-hole-cover *Please note that we can't obtain particular number or area name (eg: "Gunma 500 Fu ・86") if requested. All plates are provided as they become available after decommissioning.
    • Ah, fair enough. For the IAT, I'm using a legit GM sensor that was used on the car prior to my current build. I'll get another wideband and IAT ordered and follow up when they show up. Thanks for the help.
    • You shouldn't need to massively fatten up the mixtures for cold conditions. For one thing - 0°C is not that cold. For another, the Haltech will be using the IAT sensor to tell it how dense the air air, and calculate the correct amount of fuelling. Then the cold start enrichment is added as a % on top of that, so it should scale with the main fuelling. You might also doubt the IAT sensor at this time. You're not using one from an RB26 are you? Using a nice Bosch sensor or similar? Happens. Some wideband units take great pleasure in killing their sensors. Put another wideband in the tailpipe and compare. Or just swap the sensor to a brand new one and see.
    • Oh, my misunderstand. When the car was running, it sounded ok, but if I gave it any gas it wanted to die but caught itself afterwards. It's very different from how it was a couple months ago when it was warmer outside. The logs show that the AFRs are better during, what I assume, is warmup enrichment. Because it's cold, and air is more dense, should I work on the enrichment bit?
    • yess of course im not using 2nd hand parts from my spare engine, but the place where i live is hard to find parts for the RB20DET ,but for the RB20E is everywhere including new ones and a lot cheaper ,because for the RB20DET you have to order it overseas to get one and it cost a lot of money 3x the price to be exact. so i ask this topic because if i can use the new ones but for RB20E is it compatible or not. if not im screwed haha, not totally screwed but i have to save a lot of money first before i can begin repairing my engine, thanks for the information before.
