  • 3 weeks later...
  On 25/07/2013 at 3:56 AM, Soundboyracer said:
How's the rear end holding up under that power? I wanna start a project 240z but I'm afraid that the rear diff won't be able to handle the power. Yours is upgraded or stock?
The stock rear end of a 240z will handle more power than an rb20det can produce. This chassis comes with either a r180. Or a r200 long nose diff very similar to the r32/33/34 skyline. I ran the stick diff for a while but it was only a open 1 wheeler. I now run a dr30 skyline r200lsd which is a direct bolt in.
As far as people saying the rb20det is to small, dont forget this car only ways 1000kgI am still on stock turbo ecu and injectors and this thing has far mor power than I could ever use on public roads. I just love the way it revs so smooth and it sounds awesome.
I will be upgrading to nistune, bigger turbo and injectors in the future but when I do it will see more time on the track than the road
I have enterd a hill climb event I. September so I will add some in cab YouTube fottage from my run's.
https://www.sau.com.au/forums/topic/342533-rb-240z/page/4/#findComment-6945383
  • 2 months later...
I took my car to collingrove hill climbs a few weeks ago
I think I have a new passion. My first run was around 44 seconds.
I managed to get down to a 41 second pass on cheep Chinese street tires
Her is a video of my last run. It was only a 43 second pass because I fell of the track Half way up.
Check it out.
https://www.sau.com.au/forums/topic/342533-rb-240z/page/4/#findComment-7066347
I agree the car looks great, very neat engine install. Lots of 240/280Z here in the states, but I don't see many that are as nice as this one.
I bought a wrecked 240z in 1982, been rolled over and the roof was smashed, so I built a convertible - my first custom car. It was mechanically stock- wish I had the RB20 back in those days. I really like my RB20DET in my RX-7 and I agree the 20 has plenty of power for street driving.
https://www.sau.com.au/forums/topic/342533-rb-240z/page/4/#findComment-7067876
  • 2 months later...
I have decided that I am going to replace the rb20 with a rb25.
I came across the first issue with the conversion.
My custom engine mounts from the rb20 won't work because they fowl on a pipe which
I not sure what is because my rb20 never had it.
What is this pipe and is it important. It goes from the head and in to the block
https://www.sau.com.au/forums/topic/342533-rb-240z/page/4/#findComment-7155903
  • 9 months later...
So it's been a while.
I have the rb25det up and running in my 240z. I have already had it out for a track day
I seriously didn't think there was going to be so much of a difference over the rb20
But the extra torque makes this thing a complete animal.
There is still a lot of room for improvement but it's getting to where I want it
Before I do any more power upgrades I will be adding coil overs and adjustable control arms.
Any way here are some up to date pics.
  • Like 1
https://www.sau.com.au/forums/topic/342533-rb-240z/page/4/#findComment-7410787
    • Did a conversion on my rb20 with rb25 cam and pulley, controlled it with a solenoid (forgot the port diameter of the solenoid)  and made an oil port on the cam cap to lower pressure in the journal. Difference  is day and night, the rb20 isn't dogshit down low anymore, not a powerhouse but this had add much welcomed torque down low. Boost build a bit sooner and torque rise way more when it start building boost. Only need to deactivate the VTC past 6500/7000rpm.   Knowing how it help with only 2L, having it on 2.6L it should be a mod to think about early on as it gives a lot of performance on most on the rev range.
    • https://www.nengun.com/hks/valcon-rb26-v-cam-system   no controller but most will use ECU to control anyhow
    • Not too sure, the throttle body has 4separate plugs going to it. Im not sure if the throttle is driven by cable and the motor is for traction, cruise and something there light blue one is TPS. i don't understand why the throttle won't open with the cable until about 3/4 on them only moves the valves very slightly
    • There are other crowds doing 25Neo conversion kits.
    • Not familiar with that car at all....but that code is for the traction control. Does it have a 2nd throttle in series with the first, like the R34 Neos do, to make the traction control happen?
