While I'm waiting for my R34 brakes to arrive for the Stagea, I decided to remove the passenger mirror and hunt for any rust coming thru. Found some just starting and decided to rub it all back and treat it so it won't spread.
Two more weeks until Time Attack ... so in two weeks I'll need to fit the R34 brakes, braided lines, bleed the brake system thru with fresh DOT4 fluid, oil change, filter change, O2 sensor change, and a dyno tune.
:banana:
:banana:
took me about 3 or 4 hours to slowly cruise through my r34 brake swap
pull the restrictor out of the 34 brakes and use your existing banjo bolt with both original copper washers without modification
the 3-4 hours also included going to get more brake fluid and bleeding everything twice and taking the master cyl out cos i got air in it
the thread on the stock rotors (to pop them off the hubs) is metric fine pitch, cant remember what size tho
Jason it`s a simple thing to do ok not hard mate at all ,front Rotor`s slotted may be RDA954S,& EBC DP1671 & there Black stuff ,you can look at yellow stuff your call,
Now all this about then not fitting ???? ,LAST TIME I WILL SAY THIS OK
I FITTED THEN NO MOD`S OK,
Searched and searched for rotor and pad replacement for S2 stagea!!!! Read through all 19 pages of stagea brakes! Waiting for response on hpx pads. Just been on Bendix site again.
http://cgi.ebay.com.au/QFM-Street-Track-Br...=item56376b982c
they are also a site sponsor here, dont get the ar1m or you wil chew through rotors if your not getting them hot enough
ask them about the hpx's
and if you get them through sau they are cheaper
Fitted a boost controller today, Blitz SBC R. I don't believe the difference it made to the low end response, it seems to be on boost all the time now. :)
I checked the wideband higher up in the revs and it is running very lean, with a lot more punch. I had to drop the boost back down to a reasonable level until I can get to the tuner.
Wideband reset, torque converter lockup and petrol primer for starting on ethanol. There's still heaps of room for the ejector button though. :)
Stainless buttons are from Jaycar, they come in momentary or latching and are led backlit. (blue green and red.)
:D
You got that in in a hurry!
(all those wires along that side made it too difficult to mount the buttons?)
"it seems to be on boost all the time now." - Statement to make Jetwreck more envious by any chance?
very pretty Scotty....red is gay though!!!!!!could have at least put some pretty screws there.....should have done the carbon fibre look ;)
only kidding bud....looks gay but good :P.....not that gay is a bad thing :)
Cam, might be envious of instant boost but at least I have some real boost all the time :P.......that's the only comeback I have! :D
Turned up last night, had to get it in... :D
How did we go with the exhaust leak mate?
Exhaust manifold. Have yet to rip the heat shields off to have a look, certainly hope I have not sheared a bolt/stud... although that would be an easier fix than if the manifold is cracked.
Cam, might be envious of instant boost but at least I have some real boost all the time :banana:.......that's the only comeback I have! :D
"Real boost" all the time? Oh yeah?... well... erm... (stupid f*ck'n exhaust leak) ;)
EDIT: Suppose I should actually contribute here.
Okay, well a couple of weeks ago I installed my lovely Nismo exhaust in leu of the Fujitsubo Legalis. Same design, different muffler lol
On Monday night I decided to change the aerodynamic abilities of the rear end of my car by installing a stealth black trailer :banana:
Edited by iamhe77
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
