fixed exhaust leak and (Scotty! :domokun: ) welded up a front pipe which included my flex join and cat.
mmm, welcome back boost :laugh:
Glad you're happy buddy, cant have a fellow Stagea owner getting around with no boost. :(
Picked up my freshly rebuilt exedy 5puck clutch today
and got to have a geez under a 35gtr that was up on a hoist in the shop
wat a gorgeous piece of Japanese engineering!
Eww, my car went in today to have the puck clutch removed. It's a PITA to drive around in traffic with - I've got no idea what Adelaide traffic is like, but here in Sydney you can find yourself doing 15-20km/h, stop-start, on the FREEWAY at times.
Spigot bearing is making a hell of a noise when cold anyway, so I'm killing (at least) two birds with one stone!
Really nick? Is it heavy or just super bitey?
And is your clutch master vacuum assisted?
I've got a s14 master and pedal installed already so it's not vacuum
traffic here's pretty easy,plus the times I go to work every other sucker is already working so it's not too bad
These have actually been on the car for a couple of weeks now, but I haven't had time to take any photo's, and it's been raining most days for the last couple weeks here.
Using my iphone again, cause i dont have a real camera :D
18x9 +18, 235/40 Toyo Proxes 4
Needs to be about an inch lower all round I think, and spaced out a little at the front. I also need to get a set of centre caps for the rims.
Tried replying to this last night, but the forums were down...
It's actually bitey AND heavy. I can deal with the heaviness (even though I'm a skinny mofo), but like I said, with Sydney traffic the bite is a PITA. It's either in or out, and sometimes the car shakes REALLY badly as you try and release the clutch to move along slowly.
Nope, it's not assisted.
Here's a link to the sales threads that lead to me buying my car (I bought it from Argo just under 5 yrs ago): http://www.skylinesaustralia.com/forums/se...mp;highlite=%2B
Here's a link to his posts in the manual conversion thread (from post #63 onwards) - my car is the dark green one: http://www.skylinesaustralia.com/forums/in...t&p=1545409
^^ x2 Nick
Our new organic clutch makes the car a much more pleasant drive in traffic.
I'm soooo looking forward to having my car back so I can experience that for myself! Hopefully tomorrow, Andrew. The clutch is in, it was on the dyno this arvo when I called the workshop.
Just won a RHS Silver mirror for my S2 on Import Monster.
My RHS mirror got badly scratched on the garage wall at home, far too scratched to buff it out with cutting compound. Hopefully the air freight will get it here before the 21st of this month.
Looks hot! :whistling:
they look awesome brian! just a 20mm spacer on the front, a little lower and you'll be set
Thanks fellas :happy:
Yeah Mike, just needs a little bit more work and I'll be happy with it. Although I probably won't be able to go as low as I would like, due to the car being a daily - and I wouldn't be able to get it out of my driveway :laugh:
i bought a piece of pipe :)
its used but for $100 you can't go wrong
will get a new turbo-manifold gasket and turbo outlet gasket and some new tie rod ends and an alignment also
nearing the end of the cheap and easy mods now tho :D
Edited by pipster11
brian, looks awesome.
found a brake fluid leak in the Wilwood line setup, fixed. finally. 324mm wilwood superlite goodness.
doing a service on her at the moment, awaiting 4x 15mm thick bolt-on wheel spacers (needs 10mm to comfortably clear the calipers due to bracket setup
Loving my single plate organic from extreme. The stag is the first manual car (converted on the weekend) and Ive been driving in city traffic and finding it fine.
I personally kept away from Extreme clutches when I did my conversion. Ended up with a Nismo kit inc lightened Nismo flywheel which I sent all the kit to ACS for machining. Strong pedal feel, but very forgiving 1200kg kit. Not 'off or on' like most. I've had Extreme clutches in past cars and I haven't been impressed.
    • AFM looks to be a z32 The injectors maybe old Nismo 555cc The turbo tag when looked up seems to be a gt2871 , imagine it would have the bigger rear housing .82 all look like the mid 00's mods when he started building it up. Vac hose seems right but would need to see a diagram. Great work going up there and sorting it out, be a good club car for someone wanting a good reliable rig.  I know I would like to have it but no space and too many other race cars at the moment.
    • Heys guys I got a r32 gtst speedo is out by 10kph seems the faster I go the more it be out  just seeing if anyone else had to problem and knows how to fix it
    • I can't agree. If we hadn't all been brought up with the noise caused by the inefficiency of an ICE, no-one would actually ask for all that. An EV is like any other car, it just goes better.
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
