finally got the m35 transfered over to my name.. required a new roady but GT auto's sorted me!
(without having to replace my drivers seatbelt WIN!) - which gives me time to source a newy :)
now the legal grey area of mods can begin!
booking it in for the nismo rim fit for friday :)
HDi cooler going on tonight (slim line fan arrived!)
Edited by PetroDola
Will have some spare 33gtr swaybars soon if anyone wants some :D
I'll take second dibs if Robbie bails :)
Should also ask ... how much you looking at if/when it happens?
hey all. just had the gold version of BC racing coilovers put in my ARX, and boy what a difference it handles and responds like my sons R33 worth the money.
+1 Best suspension ive ever driven on, well worth the measly price. Over a year of abuse now with no issues.
This is what I run. Awesome eh?
got my modded piston back from the engine builder today... the pinnacle of chef mechanics!!
do u rekn this is y it didnt run? :)
No. Didn't run because it was forced into a few valves by a tool.
Fark! At what point could you not realise that it was a bad idea to force a crank with the belt off? :D
now its happened it seems so damn logical... look on the bright side of life... gna b very tastey once shes done!
that aside...
deffs gna take up a full page on what ive done to my stag in the last quarter!
I'll take second dibs if Robbie bails :P
$165 delivered for the pair, what they cost me ;)
Didn't think they were ever going to arrive so picked up some locally, but now they're sitting at the TNT depot in Sydney, should be here next week sometime.
just Pm me when you want the cash mate. keen as to not have so much body roll!.
fitted the justjap adj. upper front camber arms today - totally rooted now ;)
last weekend did the rears - already noticed how smooth the rear is over bumps, here's hoping the front is good
wheel alignment on monday.
No worries ;)
fitted the justjap adj. upper front camber arms today - totally rooted now :D
I put some adj. rear upper arms in about a month ago and pulling out a heap of camber made a huge difference! Have since also put the tight LSD and 33gtr front swaybar in (at the same time) so that made a rather noticably better difference too, just need to fit the rear swaybar and look at some adj. stuff for the front.
Replaced the HKS GT-RS with HKS 2835 ProS last week.
This won' be a huge upgrade in power but the delivery will be different. Looking forward to driving it once it has been back on the dyno and has had some road tuning.
I thought you could make 40 or 50 extra kw with the proS? Nice choice, what did it cost you?
    • Haha yea it's a bit of a weird setup at the moment, just wanted to make sure I sorted out any headaches before dyno day. At the moment I've changed the exhaust manifold, turbo and downpipe, 460lph fuel pump and rising rate reg as well as the previously mentioned headstuds and gasket. The nistune was already mapped for the car as it was and drove around for a few months no worries. The plan is to run flex fuel hence the big pump, which I've wired direct to the battery through a relay to avoid voltage issues.
    • Um. Was the ECU the same as the one previously there? I know R33's needed R32 GTST ECU's or other tomfoolery to run Nistune. This is such a wild setup. Most people would plumb in the turbo then not drive the car (i.e tow it to a tuner). What's actually changed since it last ran?
    • I'm a bit stuck with this one fellas, I recently decided to undertake a turbo conversion on my GTS-4, ended up pulling the motor to replace all the seals and do an mls head gasket and arp head studs while I was at it. Everything has gone according to plan, no oil or coolant leaks, compression checked out, and decided to give it a test before I book it in for a tune As it stands right now, the turbo only has oil lines plumbed so that I don't put boost into my untuned engine, and I'm using the factory GTS-T crossover pipe with a maf and poddy as a temporary intake. The car starts with relative ease and idles amazingly, however as the title suggests it really doesn't want to rev up, runs very smooth but almost feels choked out and unresponsive to the throttle, almost like it's running lean or something? I've triple checked my vacuum lines and timing with a timing light, injectors haven't been touched as of yet to avoid flooding the engine and worked perfectly beforehand, new plugs and coilpacks, I've even unbolted the cat just to see if it spontaneously collapsed, no dice The car currently has a nistune r32 gtst ecu installed so I have no way to check for fault codes. At this point I'm a bit stumped. Is this normal behaviour for a car with a turbo bolted onto the exhaust going nowhere? I'd imagine the turbo wouldn't cause this much restriction in the exhaust without the boost going through the intake. Any ideas? If necessary I can link a video of how it responds to full throttle while in neutral.
    • Insert tab A into slot B?
    • Instructions seem simple enough to understand.....
