This Is The New Recipe Chat Thread...
It was literally a 20 minute job :( It's been driving me bezerk!
I'm happy to not have you not pay me to not do it? Not? :D
If you want some tape I can probably hook you up. Either that or Con-Tact adhesive backed felt is good for this too.
only kidding mate. my car doesnt have many rattles.
if i hear anything i shouldnt, i just turn up the radio :D
hopefully got a buyer for my corolla so i dont have to sell my other cars due to the gfc!- quite happy as id sell my first born before i sold the stagea :D
anyone recommend a brissy local for a starter rebuild?
Edited by PetroDola
From what im told they cant be repaired as it is one of the copper coils that blows out (thats what happened to mine anyway) you will probably need to source a s/h one from a wreckers. I know they are the same as a VQ25, possibly VQ30. 3.5 has a different part number but may fit...
I have one here in need of repair if they happen to find the parts to fix yours...
3/4 of the way through fitting up my new motor with all my other bit's....hopefully tomorrow the motor and gearbox back in!
Nice intake mate... :D
You managed to keep the heat shield too. I bet its easier to work on the turbo out of the car...
sobering - i thought it mightve been an oil lubricated one and thats why it cooked.
sourcing one from wreckers isnt going to be easy around these parts , maybe down there, looks like my car is going to be bricking the driveway for weeks to come if thats the case.
what else other than an m35 has a vq25 though ?
thanks for the solid advice Scott
Edited by PetroDola
What bit can't be repaired? You have rewinders surely?
howd u do the diff ?
I got a bit carried away in the grass events at the local car show. I think I dumped the clutch too hard in reverse gear... :P
Gunna get it fixed in the new year. New diff, uni joint for the drive shafts, get the rear diff checked out, brass button clutch is a little noisy so that will get a look too.
I am keen to have an A1 drivetrain. Does anyone know if these cars will handle 8000RPM launches? :P
The J32 Maxima (2009) has a VQ25de I believe. Wouldn't think the starter would be any different to what we have.
Edited by iamhe77
I cleaned my Stagea last night! Filled it up with fuel. (full tank - $100 later FFS!)
Going to clean the interior and do a bit of a service soon!
She goes alright. Not as quick as a Turbo Datsun 1600 though :P But a hell of a lot quieter. :P
She goes alright. Not as quick as a Turbo Datsun 1600 though :P But a hell of a lot quieter. ;)
Pics?
nice man.
i'm still gonna call you Mr. Flinstone however!
intake looks nice. need to get Mr Fisher to make mine some time sooooooon.
+1, VQ25dd, but as we know, its FWD... so may fit, maybe not?
Do they have a relay or something that could be kaput?
soo...
finally got the car back in my hands today!!
alot of you know that ive smashed up my engine rather bad... that aside all is well now :blink:
done and spent a dime on it, but is very very good now!!
made 217.10 AWKW/250kw rears on the 21st run @ 16psi.... (poor car!!)
turbo pulls amazing... as per dyno graph :P
Edited by chef_stagea
not bad at all what turbs you running and computer
soo...
alot of you know that ive smashed up my engine rather bad... that aside all is well now :)
turbo pulls amazing... as per dyno graph :)
soo...
Good result and yeah, what turbo? (You need to get that 260RS out from under your name - its confusing!)
majority of the work done :)
about three hours left......If I get the two last parts it should be on the road tonight :)
Looking good mate! Good luck!
 Share
    • That's true. However, this problem has started since the tuning. First time with the return journey from the tuning. But yes, the pipe was clogged with dirt and rust. That was certainly due to age
    • Great info @tidi0x  Will definitely be handy for others and maybe me if I decide to keep the shit box H pattern.
    • Bumping this up one last time.... I wanted to follow up on the clutch slave issue. I realized that what the issue comes down to is the pocket is flat milled, and the cylinder does not want rest flat. So in order to mount it correctly you will need to make a spacer for the fingers so the cylinder is floating. I took two plates of aluminum, drilled some holes and was good. I did still need to make the relief cuts in the bell housing, as even with the spacer the bleed section still interferes. The OE bell housing the mounting holes are raised from the housing.
    • If the event in USA goes ahead will be interesting as it seems the rules will get more cars over here. Apparently the track is laguna seca too. Yeah s15, if I get a the lower dash trims, centre console and change front cross member to standard LCA position will fit clubsprint. See how rules are as i would rather do complete widebody than a bolt on flare to run the 295 with proper clearance.
    • If the car is legal height I can't see it being an issue. Found a thread on reddit that might offer some insight.   I got a ticket from a copper in QLD for my S15 being too low. They had this wheel thing on a stick that they put under the car and it hit my exhaust. Anyhow went to an exhaust shop to get the exhaust tucked up/hung a little higher and I wound the coilovers up a smidge. Don't think I even had to go back to the police station unlike when I got defected for having a carbon bonnet when I brought the S15 from the ACT to QLD and had to replace it and then rock up at a police station and have a yougish female officer who knew nothing about cars confirm that I had changed bonnets. Should have just painted the carbon bonnet yellow to match the rest of the car lol
