awesome stuff Craig - glad to hear the black beast is back on the road :)
mad job in getting it there also.
its too damn far, and im not enough mods along to need a tune myself just yet lol
that said, i havent done an oil change in a while, with the nismo ecu still learning, i got 540km from the last tank of about 70L. thats with some spirited driving also. im pretty happy with the economy of this ecu even though i have a boat load more power/torque!
yeah 540kms wtf ;) --- im lucky to get 450 off boost :S
heh ive given up on mine in the sense of mods for the time being you guys are light years ahead even you Zei20l. ill be a year away from getting a tune and an ecu at this rate - its only destined to get a highflowed turbo for the time being and a new starter :)
ill do the runner spacer and new plugs and rocker gaskets when the turbo gets done. as i cant see myself in the limited space ive got doing engine outs often - until i get a bigger garage.
Edited by PetroDola
Spotted my tractor getting 520kms from 62 litres of 98
including going up Mt Tambourine with 5 large adults in the car
Also, c34 rear strut brace fabrication begins next week ;)
He drives like a pussy so no surprise... :) lol
LOL, if it wasn't for him quoting 70 litres, I would have thought he was giving us numbers for his wife's Fiat, not the Stagea. And that would be some serious thrashing of the little buzzbox, too (the car, not the wife ;) ).
Getting a 70+ litre fuel tank into the little Fiat would be a feat, the thing is so small!
Man, this thread is way too quiet. Oh and it always makes me hungry, regardless of if the last few posts contained chat about food or not.
We need Sean, Cyrus, Mr ClownShoesTangles and others to start posting again.
i rekon using the boot i could get 70L in there :)
FYI people, did 240km on 1/4 of a tank to Port Stevens ;) all highway but needed some serious throttle to get past some morons. yes, the wife commented on the car sounding like a plane when i give it a boot full!
i guess 500+ km from a tank isnt all that bad. it needs an oil change so i expect that to get a little better afterwards
need to do the manifold spacer at some stage. not to mention the 456428475840596845673486 suspension parts to go on as well. i wish i had time.............
boy`s must have eaten to many CHILLIES lol
FYI people, did 240km on 1/4 of a tank to Port Stevens :) all highway but needed some serious throttle to get past some morons. yes, the wife commented on the car sounding like a plane when i give it a boot full!
my m35 acheived regularly 650-700 ks out of a tank cruising mainly 110-115 kph over 5000ks sunny coast - melbourne and many places in between including up to mt hotham -bairnsdale-moe.
around the sunny coast 550-600 per tank 50/50 city-country driving. ;)
Fitted L/H tailgate lamp cluster. Interesting, the cluster I had was from a tailgate that did not have the closer fitted. The plug for the cluster is four pin on the closer model, but only three pin on the non closer. I experienced the same problem on the 25G while fitting a closer.
Why Mr Nissan????????
Now all the probs with the AFM are fixed have wound the boost up to 10psi.Will check it out Monday.
cant believe i am awake and its sunday... think its time to go wash the car...... f**k i have to get out of bed to do that also....
Wash car. whats that? I gotta stop fkn with my sig and shit. i keep forgetn to save. lol. no pm atm and default skin is shizenhousen. ftl
Admins did well with the db upgrade fck all downtime, but bringing across the pms will be the true task. checkn for integrity will be a PITA. Latency seems minimal. :thanks:
Edited by dirtyRS4
Admins bringing across the pms will be the true task. checkn for integrity will be a PITA.
LOL only way Your Car in washed is driven in RAIN :D,Give me a Buzz you slack Barcket :thanks:
Just got back from the Swan Valley chuckie. Will ring later on tonight. :nyaanyaa: whats with the post edits not disappearing? lol
Edited by dirtyRS4
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
