custom sub box fits 2 X 12 inches in between the strut towers very snugly
amp goes in spare tyre hole, its a big amp :P
oh sweet did you get it made for you?? cost much? i'm looking to get one made to fit snugly behind the seats between the struts aswell!
as my currently enclosure I bought doesnt fit properly :(
haha and who needs a spare tyre when u got BASSSSsss :)
Brett @ Performance Car audio:
http://www.performancecaraudio.com.au/
If we have a stagea meet your more than welcome to measure up my setup if you want, it shouldnt be too hard to make, just made out of some MDF i assume :P
and yep no need for a spare wheel when you have bass, that and it would f**k up my 4wd system if i ever put it on :P
hahah I call my spare wheel "teh cheese cutter"
oh stag meet i'm in on that :D (DAMN SHE'S DIRTY ATM)
haha last one I was in studio.. but that's all pretty much done now... just a few more sessions!
what i'm thinking is reboxxing my 10" type R Alpine into a enclosure that fits in there nicely, but leaves me all the room i already have for my band gear... then mounting an amp on the side of it!.. :)
nope
just need to make sure you stop in on the forums so you know when its on :)
...and make sure you don't act like an attention-grabbing idiot while out on the road. SAU has a pretty good reputation across the country, we don't need people ruining that.
:D
:D
+1
hey guys,
i'm pretty sure i've got a slight leak from the round black oil reservior on the right of my engine..
it has been fine after i got it serviced but its doing this grinding whining noise coming from my power steering again haha :(
what sort of oil do i need to put into it ?? :) just gonna keep topping it up til i get it fixed!
Tomas
hey guys,
Tomas
ok it should be Dextron 3 :) couldn't find the info on here for some odd reason whistling.gif probably cos i'm a n00bdomokun.gif
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
    • I was surprised to see all the quick Jack models at the same prices on there. But yeah, grabbing one at 20% off would be great.
