Ok. I thought I'd chuck this in here because of the thread title:
TUSCAN STYLE BARRAMUNDI ON SLOW ROASTED TOMATOS ( THE SAUCE IS THE KEY icon_biggrin.gif )
TOMATOS
Pre-heat the oven to 140c
Cut the top and the tail of 4 tomatos off. Drizzle tomatos with olive oil, season with sea salt and a little pepper.
( Cooking time about 1hr 20 mins ) The can be cooked on a higher heat if you're in a rush but doing it this way you'll intensify the flavour more, almost like a large semi-sundried tomato. ( If you don't like skins, blanch them in hot water briefly and peel off skins )
SAUCE
In a sauce pan melt approximately 50 grams of butter. Cook butter until it starts to go a light brown colour ( Browning the butter will add a more nutty type flavour ). Add 2 cloves of garlic (finely chopped), 1 small chilli ( finely chopped - you can use a little capsicum if you don't like heat), ginger( grated about a teaspoon ) cook in the butter for about 20 seconds to release the oils then add baby capers about a tablespoon full along with some powdered star anise about 1/4 teaspoon, a large pinch worth.
Add white wine 100ml, cook alcohol off. Then add 100ml of orange juice, about 50ml of teriyaki sauce ( This will be the main salt content so add more or less to taste.
Reduce sauce down to about half its volume, it should start to really get a glisten/sheen to it. Probably about 15 mins cooking time.
Once the sauce is ready and the tomatos are almost ready do the fish.
2 large portions of Barramundi (3-400g's ea) thick cut from a fillet and squared off, any bloodline removed. The fishmonger can do all the main filleting/pinboning.
Pre-heat frying pan ( Hot )
Remove tomatos from over and turn up to 200c
Pat down the skin with a paper towel and season skin side with a little salt and white pepper.
Put olive oil in pan and place fish skin down ( Cook for approx 2 minutes ) Check skin, if starting to go crispy, turn fish over and put straight in the oven. Cook for about 6-7 mins. Or until the flesh starts to separate a little.
Plate up
Put 2 tomatos on the plate and dress with a little sauce. Place the fish directly on top, building a little tower. Dress with more sauce to taste ( I like lots )
To give the dish texture I also chuck on the plate some chopped pan roasted cashews. The flavour and texture really add something to the dish.
A pinch of smoked paprika around the edge of the plate is you want to tart up the look a bit more, the flavour also marries well - Finely chopped basil will also add colour and flavour
Edited by ArdentEagle
noted and emailed to wife :thumbsup:
Cheers mate. It one of my wifes/best mates favourite dishes that I make. Tell your wife to keep in mind I like things fairly acidic so depending on taste and if extra sugar is already added to the orange juice she may need to add a little bit of sweetener for balance. Demerera sugar or honey would be best imo.
If its a fan forced over maybe set it to 110-120 for that amount of time with the tomatos
Good work, Eagle. Its been a while since we've had someone actually post a recipe in here. Barramundi is a great fish to eat too, not to many bones.
Thanks buddy..... I love Barra, the taste, the texture. A brilliant fish!
I've discovered it bloody hard to write our a recipe so its easy to follow. I normally just get in the kitchen and cook.
I thought you were saving for my turbo kit, looks like the missus is on to you mate, I hope she isn't reading these threads... :P
Trying to...and failing :P
Whenever she sees me browsing IM she's like "what are you buying now!!" :rolleyes:
I tell her I'm browsing for stuff to get for the Grandis (NA4W)...hehe
Edited by ironpaw
Finally got my mig/tig welder today, time to get my fabrication on.
So who wants blast pipes, drift pipes or decat "test" track only pipes?
me .....I want a side pipe setup for track.....I want flames out the side like below. :P
Edited by Jetwreck
    • Yeah, whenever I say "HP", I mean HP. As in, at the engine. Allowing for a 25% discount from engine to typical Ozzie braked roller dyno figures, then subtracting the usual (more optimistic) US inertia dyno offset..... you get into the 600 actual engine HP territory from your 484 wheel number. 484 / 0.75 = 645   (that's Aussie rw intertia HP, converting to approximate engine HP. 645 --> 600 is discount for inertia dyno. Could actually be worse than that. But that would still be up around 600. So near enough for purposes.
    • Still fast enough to have fun (kinda). Time for a modern turbo with a divided turbine housing and a proper twin scroll manifold. I think 400-450kW is a great place to be, provided it's all in before 4500 rpm.
    • i'm not at 600 though 😢 its 484hp (356kw) at the wheels..
    • Nice. 600ish HP is probably a nice place to be.
    • In the US the EPA has been going after shops that sold aftermarket ECU tuning software that allowed you to disable CELs for things like EGR, DPF, SCR, or TWC failure. They also went after shops for selling emissions delete equipment. Their logic is that all cars built for street use have this emissions equipment and you cannot do an after the fact conversion to an off-road vehicle not intended for street use. Cobb, Hondata, and similar companies have basically all revised their tuning software such that going forward you cannot suppress DTCs for emissions-critical systems, nor can you toggle systems on and off in the tune like EGR. You also cannot adjust OBD emissions monitoring logic. You can still tune these cars. But you have to do things the hard way, basically. For example Subaru FA20DITs used to delete the TGV system to get spare analog IO for a flex fuel sensor. EGR also has to be dramatically pared back because without the TGVs the stock EGR map causes bad misfires. Now instead they have to implement the flex fuel system as a CAN bus sensor instead. IMO, this is heavy-handed but the EPA in the US gave so much leeway for so long and the aftermarket relentlessly abused that leeway to the point that they could actually see the effects of all these emissions-deleted work trucks on their air quality monitoring for cities that haven't met Clean Air Act standards. It's one thing to have a few people deleting emissions on their weekend car that spends 9 months out of the year on jack stands. It's another thing entirely for entire fleets of tradies driving around 8 hours a day on deleted diesels that emit 1000x the emissions per mile of a compliant vehicle.
