Ok. I thought I'd chuck this in here because of the thread title:
TUSCAN STYLE BARRAMUNDI ON SLOW ROASTED TOMATOS ( THE SAUCE IS THE KEY icon_biggrin.gif )
TOMATOS
Pre-heat the oven to 140c
Cut the top and the tail of 4 tomatos off. Drizzle tomatos with olive oil, season with sea salt and a little pepper.
( Cooking time about 1hr 20 mins ) The can be cooked on a higher heat if you're in a rush but doing it this way you'll intensify the flavour more, almost like a large semi-sundried tomato. ( If you don't like skins, blanch them in hot water briefly and peel off skins )
SAUCE
In a sauce pan melt approximately 50 grams of butter. Cook butter until it starts to go a light brown colour ( Browning the butter will add a more nutty type flavour ). Add 2 cloves of garlic (finely chopped), 1 small chilli ( finely chopped - you can use a little capsicum if you don't like heat), ginger( grated about a teaspoon ) cook in the butter for about 20 seconds to release the oils then add baby capers about a tablespoon full along with some powdered star anise about 1/4 teaspoon, a large pinch worth.
Add white wine 100ml, cook alcohol off. Then add 100ml of orange juice, about 50ml of teriyaki sauce ( This will be the main salt content so add more or less to taste.
Reduce sauce down to about half its volume, it should start to really get a glisten/sheen to it. Probably about 15 mins cooking time.
Once the sauce is ready and the tomatos are almost ready do the fish.
2 large portions of Barramundi (3-400g's ea) thick cut from a fillet and squared off, any bloodline removed. The fishmonger can do all the main filleting/pinboning.
Pre-heat frying pan ( Hot )
Remove tomatos from over and turn up to 200c
Pat down the skin with a paper towel and season skin side with a little salt and white pepper.
Put olive oil in pan and place fish skin down ( Cook for approx 2 minutes ) Check skin, if starting to go crispy, turn fish over and put straight in the oven. Cook for about 6-7 mins. Or until the flesh starts to separate a little.
Plate up
Put 2 tomatos on the plate and dress with a little sauce. Place the fish directly on top, building a little tower. Dress with more sauce to taste ( I like lots )
To give the dish texture I also chuck on the plate some chopped pan roasted cashews. The flavour and texture really add something to the dish.
A pinch of smoked paprika around the edge of the plate is you want to tart up the look a bit more, the flavour also marries well - Finely chopped basil will also add colour and flavour
Edited by ArdentEagle
noted and emailed to wife :thumbsup:
Cheers mate. It one of my wifes/best mates favourite dishes that I make. Tell your wife to keep in mind I like things fairly acidic so depending on taste and if extra sugar is already added to the orange juice she may need to add a little bit of sweetener for balance. Demerera sugar or honey would be best imo.
If its a fan forced over maybe set it to 110-120 for that amount of time with the tomatos
Good work, Eagle. Its been a while since we've had someone actually post a recipe in here. Barramundi is a great fish to eat too, not to many bones.
Thanks buddy..... I love Barra, the taste, the texture. A brilliant fish!
I've discovered it bloody hard to write our a recipe so its easy to follow. I normally just get in the kitchen and cook.
I thought you were saving for my turbo kit, looks like the missus is on to you mate, I hope she isn't reading these threads... :P
Trying to...and failing :P
Whenever she sees me browsing IM she's like "what are you buying now!!" :rolleyes:
I tell her I'm browsing for stuff to get for the Grandis (NA4W)...hehe
Edited by ironpaw
Finally got my mig/tig welder today, time to get my fabrication on.
So who wants blast pipes, drift pipes or decat "test" track only pipes?
me .....I want a side pipe setup for track.....I want flames out the side like below. :P
Edited by Jetwreck
    • Unfortunately,  it feels like it's been on the decline for nearly a decade. Especially as wallet racing became popular with them(biggest wallet can pay off a car that wins). It seems like a different mindset kf ownership these days. But, hopefully people like yourself keep some of the skyline scene alive.
    • A bit of data is always good, beats the Facebook experts with their opinions Although the kWs aren't anywhere near what you are after, it should give you a good indication. I have Bosch 1480cc injectors, often called 1650cc (only when run at 4bar). I run mine at 3bar base so I don't thrash the fuel system. Up top, making 437kW with boost dropping, injector duty is at 69% on E80 (might have had some residual 98RON in there)
    • I have some downtime due to winter, and just wrapped up converting the car over to flex fuel. We don't get E85 at the pump over here in Canada, but I will be running Ignite E90 Race gas. I'll be mixing it with 99-100 RON pump gas and shoot for 50% ethanol content, up to possibly 85% content if there's any noticeable gains. Here's the question. Most I'll ever want to hit is ~600rwkW. I've currently running 1200cc injectors and want to keep them under 90% duty cycle. As per some online injector calculators, I should be good with 1200's well past 600rwkw on E85. As per other calculators, I'll need 1600-2000cc's. The variety is rather amusing.  With you Australians having E85 at the pump, what realistic duty cycles are you seeing in those kW ranges on E50 & E85 on your injectors? Thanks,
    • No issues here with my PRP gears in an OEM pump housing. I did confirm all housing clearances were to spec prior though. Cheers.
    • Thread is a bit old but figured id give my input anyway just incase. Have had lots of water problems in my R32 and was getting sick of wet tools in the boot and water filling up half my taillights. I ended up finding that whenever my car had been repainted they didn't reseal the taillights to the body of the car so water was just flowing straight into the boot, this is amplified by all the water around the bootlid being directed down to the taillights so would get pretty wet whenever I washed the car or it rained. You could probably use silicone to seal them to the body but I think from factory they use a roll of automotive grade butyl rubber. Hopefully this helps you if that ends up being how the water is getting in on your car!
