Is it just me or alot of M35 owners are working in IT? Big assumption I know...
They must be since so many are online during work days. I'm sort of there as well (own a boutique ISP/phone company) but not an IT geek as such.
Why selling? You talked about it before, but why now?
All I remember of your mods is you're running Scotts old setup with ~600cc injectors, gas injection and silk roads.
I guess at the end of the day your car is only worth what people are willing to pay... Might get more if you put it back to stock and sell the parts?
OK here's the list
600cc (or was it 610?) Deka's...
Scott's hi-flowed turbo (by ATP I think?)
Plenum Spacer
HDi GT2 Intercooler
Scott's custom intake pipe
Scott's custom dump pipe+high flow cat
Fujitsubo Legalis R exhaust
Whiteline heavy duty swaybars (F+R)
Silkroads RM/W8 coilovers (less then 6 months old)
Greddy Emanage Ultimate + MAP sensor
Greddy ProfecB II EBC
AEM UEGO Wideband
4 x Kumho Ku31's (about 6 months old)
Stoptech braided brake lines
350z Brembos w/ RDA slotted rotors + QFM HPX pads (fitted in May)
JTG Liquid injected LPG
Asuka TV tuner/media player w/stock Nissan pop up display (Xanavi translation done already)
Nismo radiator cap and oil filler cap (w00t!)
Can't think of anything else...for now.
Tuned for both E85 and LPG. Made 270+ awkw on E85 and 250 awkw on LPG (I'm in the process ot fitting larger gas jets on to see if I can make more on LPG)
Can't really part it out unless I put a stock turbo back on...which I don't have...nor can I be bothered paying for...
Edited by ironpaw
OK here's the list
Plenum Spacer
HDi GT2 Intercooler
AEM UEGO Wideband
I'll give you $3.00, cash, final offer!
Dunc has the Kenstyle, but I think thats only because it was on the car when he bought it.
I'm really happy with the factory Aero kit. I don't think it needs anything else (except a wing, which mine didn't have until I added the Nismo wing).
Freeway Dolphin do kits too.
Anyway, back on topic, why the sale?
Has anyone in Australia kitted out their M35 yet?
I know Dunc has the Kenstyle, but what about everyone else? Most people are pretty happy with how they look from factory?
I have a full Impul kit, but like Dunc it came like that :)
dont sell Jethro.. you'll regret it!
Spoken like someone living with regret ??? BTW, how's it going mate?
I wonder if it's a Melbourne thing? If Scotty announces he's selling, the whole M35 world will implode... tear in T/S continuim & all that
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
