"Medieval times of the many 50 seaming machine it is in the midst of part many exhibiting to in addition to."
God I love the Google translations of IM! Constant source of entertainment!
Love it, but I don't think IM use Google to translate on their site.
You will get a different translation if you cut the auction portion of the url out of the address bar and put it into Google Translate (or just into the address bar in a new tab if using Chrome).
wow. loads of hours gone into Uni this week. 7x lectures to write out into revision note books takes a long time!
throw in practicals/tutorials/workshop assignments & Ive got it cut out for me !!! doing well though, and importantly Im enjoying it.
bloody brake line. had front braided lines made up Dec last year, today found front left has split where it screws into the caliper.
the line is like 40cm long - how long should it be? I reckon it is 2inches too long.
its obviously too long as it has bent itself into a right angle at the caliper fixture for some reason, and the metal fitting (joining line to banjo) has rubbed on the compressed line. not happy - dont really have the time to waste on it.
Good to hear your course is going well Brendan, was a gutsy move to go and do something completely different.
Best of luck mate; amazing how much easier it is to knuckle down & do the study when you actually enjoy the subject matter.thumbsup.gif
As for your lines; the last ADR approved braided lines I had made; had a short rubber sleeve crimped into the swage; to prevent exactly what you're talking about.
Do you have an OEM to use as a sample?
Thank you dale!
Yes its a huge challenge - Im not exactly a 'sciency' type but I'll be trying to put in my best efforts. Very tiring, but Im enjoying applying myself to the task Ive set for myself; we'll see where it goes. Ive got my goal, a vision, and need to work at the little weekly steps in getting there.
I noticed the lines that were made up (ADR approved) uses a metal sleeve instead of the rubber sleeve. On full lock over a speedbump or spoondrain it must be knocking against the swaybar link bracket, or thereabouts. Looks like I'll have a pair of custom banjo-type lines made up end of this week, to lose that 1.5inches that protudes out of the caliper with screw-in type lines. Must be a space/fitment issue due to the caliper brackets and 322mm discs I run; obviously puts everything out of kilter compared to the stock setup.
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
