Big big wet has come to the southeast Everyone safe? Evacuated, or flooded?
Nice....but it won't go with aaalllll the other bits I have coming! Plus that's not part of the widebody Nismo kit! ;p
Takero's (?) front bar Craig - surely that will match some of the bits coming? Just needs paint..... :whistling:
yummy
i'd be happy with just a front lip & side skirts...
contemplating whether i should get the skirts for sale on ebay
There's more then one nismo kit for our cars?
I thought this one was it?
Nope, just one Nismo kit for NM's and one for PM's.
They are only "widebody" if you modify them to be and are made for RS/RX's only
Yes
mmmm.... Takero's ricey goodness
Interesting...got a pic?
Yes
concur...bit OTT riceness...
Damn you!
Don't won't front bar but the back looks like porn IMO!
1331192222[/url]' post='6266681']
Ahh, just heaps of awesome wagon action; hard to explain, coupe owners wouldn't understand...nyaanyaa.gif
Haha same old shit.. Given up on cars for the time being so just driving around the Jaffa
1331208343[/url]' post='6267141']
No gay s14 shit bro from another mo!
We have the speed and handling...just working on aero!
2 tonne of our of control goodness!
haha I hear your getting a wide body? I thought stags already have that
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
