Who knows where their going to put a T62R in that engine bay, but if you make enough space I guess where the airbox sits.
I always thought the airbox was overrated any how.
Needs to be rotated 90 degrees, add some creative exhaust manifolds and an inlet track that puts the pod outside the engine bay... then ceramic coat everything!
Would be able to run a radiator and air con then.
I'm more interested in the gearbox. Looks like an R34 GTR box. Not sure what is custom to make it fit, besides the gearbox crossmember?
Also, is the extended sump really necessary on these things, or are they just doing it out of habit/experience with other motors?
The r34 box needs extensive mods to fit Ryan, custom cut and shut bellhousing, major floor pan modification, custom gearbox mounts etc. I would say there is an easy 20k blown there at least.
The extended sump is only needed for the oil return, my car was fine at the track oil pickup wise, so our stock setup works very well.
Didn't look like the bell housing had been cut and shut to my untrained eye though?
Not that I have a trained eye by any stretch, nor do I know the GTR gearbox design.. but is that actually a factor weld?
The best chance we had was the 350z guy who went AWD, he was planning to cad the bellhousing and sell an AWD kit for the 34 box. Costs were too high unfortunately. RWD should be easy with a V35 manual halfcut. Still looking for one though...
Costs to CAD it were too high?
So he didn't finish his AWD conversion, or he did but the kits worked out too expensive?
Hows your conversion going Scott? Thought you'd be doing RWD skids by now...
He finished his, just the parts would cost too much to replicate.
I need to find a V35 halfcut first Ryan, do you have one? :P
(The auto is being strengthened some more, I should have it back on the road next week.)
What do you need off the V35? Do you really need the whole halfcut?
EDIT: Don't we have a thread that we're supposed to discuss this shit in? :P
Hello Gents.
Just so happens I had a little conversation with the Owner of Mercury Motorsport at the SAU nats about this car, and found out some details. I'll read the rest of the thread, since I've been gone and fill in the blanks.
Ok, so, I'll give some general info, because I know the owner still pokes round these parts, so no numbers or anything in his respect.
The owner would like it to be a daily driver, but I think it will turn out a weekend car. He was thinking of going t51, but once the t62 was looked at, change was made.
So, the motor is a crate motor from gtm in the US. Basically mercury told him to "tick every option box" when building the motor. Took 4 months to get here. Cost a lot of money.
We all know about the gearbox. They will use the stock attesa pump system to run the transfer case.
Front and rear diffs are yet to be decided on, but LSDs will be used.
The turbo will sit off custom made exhaust manifolds, point forwards tucked under the front reo. This will require a custom radiator. Owner wants to retain AC, but I think realistically the AC will be deleted.
A new p/s engine mount will be fabricated to clear the manifold, and dump.
Obviously external gate or some kind.
Ecu will be a haltech platinum pro ps2000. Maybe with a custom dash.
Owner bought the intake plenum.
So all in all, this is a serious investment on behalf of the owner. Once the teething issues are sorted out, which there will invariably be, this will represent the craziest M35 worldwide.
I hope the owner doesn't mind me posting, but I think we should all be able to share in his excitement about this build.
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
