After driving Aarons stock example today I realized the Stagea will never be as good on the track, plus this cost me less than a manual conversion.
Aaron's jelly, I bought mine for $7k and he had to haggle the guy down to 18 grand. I won't be selling either car, I just found my new track hack. :whistling:
Definitely a better choice than tracking the bus Scotty; keep it for high speed grocery and school runs!
FYI, I can also get Emo suspension parts... ;)
Edited by Daleo
Fkn photoshop show off Dunc :P
Nah, I don't hate em either. They have a place. That place is racetrack and rally. Not stanced out in car parks with posers. And as Dale said, on the streets they look fairly ridiculous.
Everything works there, and it's a quality tool. Can't wait to see what you do with it Scotty.
I actually don't hate them at all; responsive, punchy package, and with some simple mods, they'll crush almost anything under 100k.
My mates Emo 9 has an exhaust, filter, hard pipe kit, and a walbro pump; 250awkw. It's like an angry dog, straining at the leash; just waiting to be set loose.
Less than 3k in mods INCLUDING the tune; it's gotta be good for a low 12/high 11.
The problem lies in the tens of thousands of P platers driving kitted stocker NA Lancers, and the fact that every douche in a Crummydore wants to run you; even in the Maccas drive thru.
Driving an Evo is the automotive equivalent of running through street holding a massive red dildo above your head, yelling "LOOK AT ME! LOOK AT ME!" People are looking, but for all the wrong reasons.
I hate the rear wing, and the fact that EVERYONE knows what it is. They beg to be driven hard, but if you do; everyone thinks you're a wanker.
I much prefer to tread softly, and carry a big stick.
This - all of it!
ESPECIALLY that last line. :D
i agree, im definitely not taking this down the 'hardpark' direction..
its all useless, the amount i had to do to the 200 to get it controllable again was rediculous.
I have again predicted where your car will be Aaron.
Bow down at my amazing photoshop abilities.
I can almost smell the desperation! It's just being there...
You has mad skills brah.
Edited by Daleo
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
