just got off the phone with Shannons Insurance...
Not impressed.
1st - they don't know my car. That's fine, not many people do.
2nd - after telling them every little bit of detail about my past infringments/mods etc he comes back and says "we can't insure you because your car has too many mods. It needs to be in a garage"
3rd - I told him as I'm moving to a new house soon which HAS a lockup garage, can he give me a quote. He goes for another 10 min and then comes back and said "no, we can't give u a quote until you've moved into a house with a garage".
I guess I need to ring up again and lie just to get a f**king quote. idiots...wasting both our time. If they don't/can't want to insure me just f**king say so from the start...
Thank goodness JCI's online portal is so easy to use...
They should; several other forum members are insured with them. I had no issues.
I've heard of this before; I think it really depends who you get on the line when you ring, try again.
Logged in to turn off email notifications.
Bye stagea people, I no longer own any nissans, Just moved interstate and didnt sell the bucket(accent) in time so will just keep it for a while and not have anything fast(also to much cool shit coming out in the next year to buy new now!), I seem to get the train to work anyway and its better to have something I can park at the station and it uses f**k all fuel.
Farewell.
-Ryan
Agreed.
I have been with Shannon's since day 1... which literally was day 1 for M35 Stagea's!
Jethro - The dude you got will be going by Redbook which only states ARX models last time I checked.
Strange as I have never had any issues with any of the Shannon's people I have spoken to.
Also odd is that there isn't a limit on mods... just some of them will bump up your premium considerably (turbo, boost controller, engine management are biggies).
Maybe you got a new guy on a bad day? Dunno. Try them again.
Edited by iamhe77
Agreed.
Maybe...
Funny too - the guys said "since your car has so many mods it needs to be in a garage..." and "we'll need to having driver restrictions since its a very hi powered vehicle...."
I didn't even tell him any power figures! meh...
I might try again when I've moved into my new place I guess.
i had no problems with mods either, put around 8-10k of mods on the car and premium went up around $200 per year i think
yes ALL imports need a garage with shannons, locally delivered cars dont. which is weird, my fiat is probably more rare than the stagea, and i dont have to garage it.......
Farewell.
-Ryan
c'ya Ryan, take care mate
sent PM wishing you well
washed the stag on the weekend :D
I cant believe how shiny it is when you wash it after a month (or so) worth of dirt!!!
(but then I see all the little bits that need detailing too sad.gif )
Oh...I should wash my car.....I haven't given my car a wash in about 2 months....let's just say a mate of mine goes to me....your car is turning cream (it should be pearl white)....that's how long I haven't washed it for...it's been either too cold or raining to get it washed
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
