Ok. I thought I'd chuck this in here because of the thread title:
TUSCAN STYLE BARRAMUNDI ON SLOW ROASTED TOMATOS ( THE SAUCE IS THE KEY icon_biggrin.gif )
TOMATOS
Pre-heat the oven to 140c
Cut the top and the tail of 4 tomatos off. Drizzle tomatos with olive oil, season with sea salt and a little pepper.
( Cooking time about 1hr 20 mins ) The can be cooked on a higher heat if you're in a rush but doing it this way you'll intensify the flavour more, almost like a large semi-sundried tomato. ( If you don't like skins, blanch them in hot water briefly and peel off skins )
SAUCE
In a sauce pan melt approximately 50 grams of butter. Cook butter until it starts to go a light brown colour ( Browning the butter will add a more nutty type flavour ). Add 2 cloves of garlic (finely chopped), 1 small chilli ( finely chopped - you can use a little capsicum if you don't like heat), ginger( grated about a teaspoon ) cook in the butter for about 20 seconds to release the oils then add baby capers about a tablespoon full along with some powdered star anise about 1/4 teaspoon, a large pinch worth.
Add white wine 100ml, cook alcohol off. Then add 100ml of orange juice, about 50ml of teriyaki sauce ( This will be the main salt content so add more or less to taste.
Reduce sauce down to about half its volume, it should start to really get a glisten/sheen to it. Probably about 15 mins cooking time.
Once the sauce is ready and the tomatos are almost ready do the fish.
2 large portions of Barramundi (3-400g's ea) thick cut from a fillet and squared off, any bloodline removed. The fishmonger can do all the main filleting/pinboning.
Pre-heat frying pan ( Hot )
Remove tomatos from over and turn up to 200c
Pat down the skin with a paper towel and season skin side with a little salt and white pepper.
Put olive oil in pan and place fish skin down ( Cook for approx 2 minutes ) Check skin, if starting to go crispy, turn fish over and put straight in the oven. Cook for about 6-7 mins. Or until the flesh starts to separate a little.
Plate up
Put 2 tomatos on the plate and dress with a little sauce. Place the fish directly on top, building a little tower. Dress with more sauce to taste ( I like lots )
To give the dish texture I also chuck on the plate some chopped pan roasted cashews. The flavour and texture really add something to the dish.
A pinch of smoked paprika around the edge of the plate is you want to tart up the look a bit more, the flavour also marries well - Finely chopped basil will also add colour and flavour
Edited by ArdentEagle
noted and emailed to wife :thumbsup:
Cheers mate. It one of my wifes/best mates favourite dishes that I make. Tell your wife to keep in mind I like things fairly acidic so depending on taste and if extra sugar is already added to the orange juice she may need to add a little bit of sweetener for balance. Demerera sugar or honey would be best imo.
If its a fan forced over maybe set it to 110-120 for that amount of time with the tomatos
Good work, Eagle. Its been a while since we've had someone actually post a recipe in here. Barramundi is a great fish to eat too, not to many bones.
Thanks buddy..... I love Barra, the taste, the texture. A brilliant fish!
I've discovered it bloody hard to write our a recipe so its easy to follow. I normally just get in the kitchen and cook.
I thought you were saving for my turbo kit, looks like the missus is on to you mate, I hope she isn't reading these threads... :P
Trying to...and failing :P
Whenever she sees me browsing IM she's like "what are you buying now!!" :rolleyes:
I tell her I'm browsing for stuff to get for the Grandis (NA4W)...hehe
Edited by ironpaw
Finally got my mig/tig welder today, time to get my fabrication on.
So who wants blast pipes, drift pipes or decat "test" track only pipes?
me .....I want a side pipe setup for track.....I want flames out the side like below. :P
Edited by Jetwreck
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
